With wire awg, a larger number means a smaller wire. What is the proper convention for making comparisons between wire awg? For example if you you say it a wire needs to be larger than 12awg, is that more or less copper? Should the word larger/smaller be avoided and lower/higher used and clarification be asked when they are used?
  • \$\begingroup\$ Just say "bigger wire" instead of "bigger AWG". \$\endgroup\$
    – The Photon
    Commented Jul 14, 2020 at 22:12
  • \$\begingroup\$ I always go "A larger gauge than 12AWG". Those familiar with AWG know this will be 11 or "smaller". Those that don't know it needs to have a larger diameter than 12AWG \$\endgroup\$
    – user16222
    Commented Jul 14, 2020 at 22:18
I see the point of confusion but have never given it much thought. Lower/higher is a LOT more confusing than larger/smaller.
If someone said "larger/smaller than 12AWG", to me that would mean more/less copper, so a numerically lower/higher AWG. I probably think this way since "larger" and "smaller" have physicality to them; A wire can be physically larger or smaller. In short, "AWG" is synonymous with "size" or "diameter".
If they said a "higher/lower AWG", that would give me pause unless the context was clear. "The current is too high, you need a wire gauge." it really doesn't matter what the relative adjective is. You know what it is trying to say. But I don't think I've had anyone communicate AWG to me using this method.
But you probably should just say wire/conductor diameter.
I would use "heavier" or "lighter" instead.
According to Wikipedia:
The diameter of a № ''n'' AWG wire is determined, for gauges smaller than 00 (36 to 0), according to the following formula: $$ d_n = 0.005~\mathrm{inch} \times 92^\frac{36 - n}{39} = 0.127~\mathrm{mm} \times 92^\frac{36 - n}{39} $$
It's hard to see where the difficulty lies if you can raise 92 to fractional powers in your head. :^)
  • \$\begingroup\$ Not so easy, mostly. 36 gauge is easy though. \$\endgroup\$ Commented Jul 14, 2020 at 22:17
  • \$\begingroup\$ @SpehroPefhany "Hmmmmm. You haven't sized your wire properly. You need an easier AWG." \$\endgroup\$
    – DKNguyen
  • \$\begingroup\$ "Thicker/thinner" would also work. \$\endgroup\$ Commented Jul 14, 2020 at 23:05
