My issue concern the definition of series connection of multiple transmission lines described by the so called constant parameter model, to be next simulated in EMTP-RV. Let us take as an example two transmission lines of length respectively $$\Delta x_1,\Delta x_2$$ described by the telegapher's equations
$$ L_i\frac{\partial I_i(x,t)}{\partial t}=-R_iI_i(x,t)+\frac{\partial V_i(x,t)}{\partial x}\\ C_i\frac{\partial V_i(x,t)}{\partial t}=-G_iV_i(x,t)+\frac{\partial I_i(x,t)}{\partial x}. $$
with i=1,2. Is it possible to obtain an equivalent aggregated model in the form of telegrapher's equation via linear combination of the two systems? By setting for example $$\Delta x_{eq}=\Delta x_1+\Delta x_2$$ which are the corresponding values of $$L_{eq},C_{eq},R_{eq},G_{eq}$$ ?
