The above is pretty much all there is to the question. By "can you," I mean will it be properly effective / are there any tips? If not, why? It seems that this ought to work, but I can't find info online.
Thanks.
Thanks.
Sure; the capacity of a plate capacitor (Wikipedia is your friend!) proportional to three things:
Your isolating will probably have dielectric constant higher than that of air.
What it also might have might be a higher or lower isolation strength (i.e. at which voltage there will be arcing through it).
Also, there might be higher losses than in an air-filled capacitor when using the capacitor at high frequencies.
