-1
I made a simple circuit following this schematic. The load is several motors. At the gate is 3.3V while the source is GND. The pull-down resistor at the gate goes to the same GND as the source.
When I put 5V at the gate, the drain outputs GND. However, when I remove the 5V, the drain starts outputting 5V.
What could have cause this and how do I fix it?
I've tried:
  1. Raising the voltage at the gate to 10V
  2. Switching the MOSFET out
  3. Also changing and resoldering on a brand new board
Both of them did not work. I have read that I could try lowering the output impedance but I do not know how to do that.
    \$\begingroup\$ Post a schematic that makes better sense. \$\endgroup\$
    Jul 17, 2020 at 11:15
  • \$\begingroup\$ Post a schematic that shows all of the circuit. Before doing that you may want to consider how a good schematic is drawn. The small evidence in the snippet that you show gives an indication that schematic is not currently well drawn. \$\endgroup\$ Jul 17, 2020 at 11:31
  • \$\begingroup\$ What is the supply voltage? If it's 5V, you have not described a problem. \$\endgroup\$
    – user16324
    Jul 17, 2020 at 11:41
  • \$\begingroup\$ sorry for that it's my first time posting, here's a slightly simplified version of the full circuit \$\endgroup\$ Jul 17, 2020 at 12:00
  • \$\begingroup\$ You have shown +24 V on the schematic but your post suggests that you are using a +5 V supply. Which is it? What are R2 and R3 supposed to do? \$\endgroup\$
    – Transistor
    Jul 17, 2020 at 12:20
If I read you schematic correctly, it should be like this:
When you close the switch, R1 and R2 becomes parallel. This makes \$V_g\$ less than 1V which means the MOSFET can never turn on.
According to the schematic, it shouldn't be. Either your schematic does not match the circuit or there's something wrong with the circuit.
  • \$\begingroup\$ nah it would seem that my circuit and the schematic matches up. I redid it a few times with the same results and i checked the connections of everything repeatedly. I have heard of people receiving "factory fakes" when they order MOSFETs so I have bought new parts (this time from a legit source) and will try again when they arrive \$\endgroup\$ Jul 17, 2020 at 14:24
