I have a 10 port USB extender hub and connected to it are 10 arduinos. Is there a way by which I can send the same program to all of them at one go and not program them one by one?
  • \$\begingroup\$ Run 10 instances of avrdude. \$\endgroup\$ Jul 18 '20 at 14:07
  • \$\begingroup\$ But that would be like manually opening 10 instances and then uploading code through all. If I want to send the same program to all at once? \$\endgroup\$ Jul 18 '20 at 14:09
  • \$\begingroup\$ How do you send the same program to all at once... you run 10 instances of the programmer in parallel. That could be done via a script automatically launching 10 child processes. In any case, this site is intended for electronics design rather than use. \$\endgroup\$ Jul 18 '20 at 14:22
  • \$\begingroup\$ Got it, so scripting is the way. \$\endgroup\$ Jul 18 '20 at 15:14
  • \$\begingroup\$ Your previous question: Upload firmware to many controller ICs at once \$\endgroup\$
    Jul 18 '20 at 16:08
