I have 4 batteries (18650) 3.7 volt each and i want to connect them in series to get around 15 volts, can i do that without having a bms? Just directly connecting them together?
Note: i do have a charger specifically to charge this type of batteries, so if your answer is "bms is better for safe charging" please don't, charging isn't my concern.
    \$\begingroup\$ What happens when the first of your series cells goes flat? \$\endgroup\$ – Transistor Jul 18 at 15:02
  • \$\begingroup\$ For a while yes. At some point the capacitances of the individual batteries will drift apart and the lowest one will experience worse and worse overcharge and undervoltage each cycle until something gives. Fiery explosion? Slow gradual performance loss? \$\endgroup\$ – winny Jul 18 at 20:13
Bms is(should) also protecting from over discharge and cell voltage reversion. Discharging cell to 0v maybe not start a fire but will render it useless.
| improve this answer | |
  • \$\begingroup\$ No dedicated LI-ion charger mentioned by OP would charge cell that is below 2.5V. \$\endgroup\$ – zajc3w Jul 18 at 22:01
It depends on chemistry. For example the Sony Konion doesn't need the BMS at all costs. It's a LiMn chemistry (IMR) also used in Samsung INR battery. Usually you will find those batteries in hand held tools battery packs, Makita does use Sony Konion with overvoltage and short circuit protection, no voltage measurement over each cell and BMS is done in their battery packs.
Simplified Makita Protection circuit:
In case of overcurrent or short circuit the fuses F1 or F2 will blow. In case of overvoltage the comparator turns on the MOSFET which turns on the heating elements and starts to melt the fuse until the battery pack is disconnected from charger, preventing the eplosion of the battery.
The protector fuse and heating element link
