I've recently bought 5V/1A USB power supplies, and since the packaging was slightly damaged (specified in the auction I bought it from), I thought about testing it before connecting to anything sensitive.
Since it's a USB-A receptacle and I have the corresponding socket in my parts supply, I was thinking simply about soldering leads to Pin 1 and 4, connecting those through a resistor, and the connecting a multimeter in series or in parallel to the resistor for measuring current and voltage output. I'll be using 10W resistors to stay on the safe side (with the lowest resistance of 5 Ohms, of course).
My questions is: is there something inherent in the USB standard that will cause problems, or worse, hazards, with this test setup?
Also, a side-question: is it safe to base this type of setup on a typical breadboard and 22 AWG cables?
