In another question someone ask about repair of laptop PSU. I cannot find it ATM - possibly because it was closed as about repair and off topic.
However an attached schematic to one of the answers had a sideway transformer (XFRM1 on schematic below)) surrounded by 2 caps (C1 and C2) before transformer to (I presume) lower the voltage. As far as I can tell it doesn't 'do anything' which leads me to think it may be a safety feature. What may be a purpose of it?
It is a common mode choke, and it works to prevent high frequencies conducting back to mains. It is required for switch mode power supplies to pass the required electromagnetic interference tests.
| improve this answer | |
  • \$\begingroup\$ except that this is not a switched mode power supply, and perhaps it is used as a line filter to reject incoming line noise, as common in audio applications and measurement equipment \$\endgroup\$ – P2000 Jul 19 at 3:37
