I'm trying to find a small, affordable, solid-state SPST relay that I can use for an Arduino project. I've made an analog clock using regular electromechanical relays, and it works fine. But the clicks (once every 15 seconds) are driving (especially) my wife and me crazy!
I have found a 6-pin DIP SSR, a Panasonic chip called "AQV210E" (https://www.digikey.com/product-detail/en/panasonic-electric-works/AQV210E/255-1143-5-ND/251915), with a detailed description that reads: Solid State SPST-NO (1 Form A) 6-DIP (0.300", 7.62mm)
It looks to me as if the AQV210E will work, as long as I use appropriate resistance for its input (Arduino uses +5v or 0v digital pin output signal, and this chip's input is rated for only 1.14vdc). It seems to me (I admit I'm a novice/hobbyist) that the input of this chip should behave just like any LED being powered by a 5vdc signal... correct resistance between Arduino digital pin output and AQV210E chip input should allow successful On/Off behavior without frying the AQV210E.
Output-wise, I'll be making and breaking a ground connection for one or two LEDs at a time, so very little current is involved. The AQV201E isn't a zero-crossing relay, and it appears to be useful for a DC in / DC out application.
Can someone tell me if this AQV210E chip might work for me?
  • \$\begingroup\$ you are asking if the SSR is suitable for switching an unknown load \$\endgroup\$ – jsotola Jul 20 at 17:04
    \$\begingroup\$ Why don't you just use an NPN transistor? \$\endgroup\$ – Elliot Alderson Jul 20 at 17:58
  • \$\begingroup\$ Why does your clock rely on relays? For timed activation of something that could be reasonable, but it's innapropriate for just being a clock. This seems like an XY problem. \$\endgroup\$ – Chris Stratton Jul 20 at 20:37
  • \$\begingroup\$ jsotola, The "unknown load" is apparently successfully hidden in my question. It says, "Output-wise, I'll be making and breaking a ground connection for one or two LEDs at a time..." That's the load. \$\endgroup\$ – ugfrog Jul 20 at 22:16
  • \$\begingroup\$ Chris Stratton, It's not the clock, exactly, that needs the relays. The Arduino Mega I'm using doesn't have enough pins to control the LED that represents each second, minute, and hour with separate signals. I'd need 132 pins just for those features, to say nothing of other things the clock does. So I'm using relays to connect the grounds of the LEDs in blocks of seconds LEDs, minutes LEDs, and hours LEDs. Using 7 SPST relays, I can reduce the number of required pins to just 39. It works great - just clicky with electromechanical relays! \$\endgroup\$ – ugfrog Jul 20 at 22:21
You are correct about driving it like a typical LED. \$R=\frac{Vcc-Vf}{I}\$
Drive it with enough current (\$I\$) to cause the output to switch on fully (Looks like 1.6mA to 3.0mA is their max required turn on current. They characterize it with 5mA though in the graphs).
For the load side, it can only handle 130mA, so do not exceed that.
Tick - Tock -Tick -Tock ... silence...
| improve this answer | |
  • \$\begingroup\$ Aaron, It's nice to hear that I might be on the right track. Thank you! \$\endgroup\$ – ugfrog Jul 20 at 22:26
