I a working on a project around the STM32H7 (Nucleo STM32H743ZI2) on which I am using the user USB to communicate through CDC interface. Everything is working fine, however, I just noticed that this User USB port is not powering the board. I am pretty sure initially it was, but well it's no longer the case.
what is the CubeMX settings to enable this user USB port to power the board? The goal is to use this USB port to connect to the PC communicating with the board (and not the STLINK USB).
right now I have the USB_OTG_FS set to Device_Only, activate_VBUS set to VBUS sensing and activate_SOF is enabled.
thanks!
