I am using an Arduino Nano clone to program and use a small I2C, SH1106 OLED.
While trying to create a function to give me the length of a char* (as all the solutions I found were for strings, and it would complain if they were replaced by char*,) I wanted to convert the integer I got back to char* (due to how the library I am using works) and as such, I used sprintf. Everything was working just fine until I added sprintf, now it looks like my board is bricked, as I cannot upload anything anymore to it.
Function which broke everything(which was part of the code block below):
char* len(char* msg){
int c=0;
char* length;
while(msg[c] != '.'){
c++;
sprintf(length, "%d", c);
return length;
Code I'm trying to upload:
#include <OneBitDisplay.h>
#ifdef USE_BACKBUFFER
static uint8_t ucBackBuffer[1024];
#else
static uint8_t *ucBackBuffer = NULL;
#endif
#define SDA_PIN 32
#define SCL_PIN 26
#define RESET_PIN -1
#define OLED_ADDR -1
#define FLIP180 0
#define INVERT 0
#define USE_HW_I2C 1
#define MY_OLED OLED_128x64
#define OLED_WIDTH 128
#define OLED_HEIGHT 64
OBDISP obd;
void setup() {
int rc;
rc = obdI2CInit(&obd, MY_OLED, OLED_ADDR, FLIP180, INVERT, USE_HW_I2C, SDA_PIN, SCL_PIN, RESET_PIN, 800000L); // use standard I2C bus at 400Khz
void loop() {
char* msg = "This is a test to see if i can manage to scroll text vertically on this oled screen right here. I will write some more words here so that the text will go off screen, as the small font is really smaller than I originally expected.";
scroll_func(msg);
delay(1000);
void scroll_func(char* msg){
obdSetTextWrap(&obd, 1);
int start=3;
for(int i=0; i<1380; i+=126){
if(start>=0){i=0;}
obdFill(&obd, 0x0, 1);
obdWriteString(&obd, i,0,start,(char *)msg, FONT_SMALL, 0, 1);
if(start>=0){start--;}
delay(1000);
Error code received when trying to upload:
Arduino: 1.8.12 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Users\DRAGOS~1\AppData\Local\Temp\arduino_modified_sketch_983438\scroll_func.ino: In function 'void loop()':
C:\Users\DRAGOS~1\AppData\Local\Temp\arduino_modified_sketch_983438\scroll_func.ino:28:15: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
Sketch uses 7894 bytes (25%) of program storage space. Maximum is 30720 bytes.
Global variables use 826 bytes (40%) of dynamic memory, leaving 1222 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Dragos SPiridon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Dragos SPiridon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b57600 -D -Uflash:w:C:\Users\DRAGOS~1\AppData\Local\Temp\arduino_build_269143/scroll_func.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Dragos SPiridon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\DRAGOS~1\AppData\Local\Temp\arduino_build_269143/scroll_func.ino.hex"
avrdude: writing flash (7894 bytes):
Writing | avrdude: stk500_recv(): programmer is not responding
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
From what I can deduce, the board cannot be written to anymore. It is still detected in device manager(Windows) as CH340 device, and "Get board info" in the IDE still works, but nothing uploads to it.
And yes, I have tried all of the first options such as switching COM ports from USB3 to 2, it is running the old bootloader.
