For this hypothetical entity:
entity test is
  port (
    a_out: std_logic
end entity;
The a_out must drive three signals to the same value where the test entity is instantiated. Now one can create an std_logic signal and port map it to a_out and then drive the other three signals from this port mapped signal. Something like this:
signal bit_signal : std_logic;
signal x : std_logic;
signal y : std_logic;
signal z : std_logic;
test_i: test
  port map (
  a_out => bit_signal
x <= bit_signal;
y <= bit_signal;
z <= bit_signal;
It would be great if the intermediate bit_signal is not required and the a_out can directly drive the signals x, y, z doing something like this:
test_i: test
  port map (
  a_out => x, y, z
I don't think VHDL 2008 allows this, I cannot say anything about the VHDL 2019 though.
    \$\begingroup\$ Why do you even need to split up a duplicate signal like that so it has identical names? You already need an intermediary signal anyways to connect port-to-port and you can just run that one everywhere. If you need to perform an operation you just read the signal wherever the operations are done and write the outputs separately. In what case do you need three identical signals to have different names? I can think of none. Also, a comma under a port map moves to the next signal to be assigned so I would assume no. \$\endgroup\$ – DKNguyen Jul 21 at 18:17
  • \$\begingroup\$ @mbedded What you posted was a signal assignment. OP is asking about a port assignment which uses => \$\endgroup\$ – DKNguyen Jul 21 at 18:44
You could try using alias, something like this:
signal x: std_logic;
alias y is x;
alias z is x;
test_i: test
  port map (
  a_out => x
| improve this answer | |
  • \$\begingroup\$ Unless the OP clarifies why he needs this, or what he really needs, this is as good as any approach. \$\endgroup\$ – Brian Drummond Jul 21 at 19:34
