#include <IRremote.h>
#include <AFMotor.h>
AF_DCMotor motor(1);
int RECV_PIN = 14;//The definition of the infrared receiver pin 11
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
  Serial.begin(9600); //Open serial
  irrecv.enableIRIn(); // Initialization infrared receiver
  motor.setSpeed(255);
  motor.run(RELEASE);
  Serial.println("start");
  motor.run(FORWARD);
  delay(1000);
void loop()
  if (irrecv.decode(&results)) {
    if(results.value==0x3D9AE3F7)
      motor.run(FORWARD);
      delay(2000);
    else if(results.value==0x1BC0157B)
      motor.run(RELEASE);
      motor.run(BACKWARD);
    Serial.println(results.value, HEX);//Wrap output in hex receive code
    Serial.println();//For ease of viewing the output to add a blank line
    irrecv.resume(); //Receiving the next value
The motor shield is not working when I use an IR receiver.
I tried connecting the IR receiver to different analog pins but it didn't work. I guess it's due to some error in my code but I am unable to figure it out.
  • \$\begingroup\$ This question is missing too much critical information to be answerable. You need to show both the electrical signals of the motor shield and the code which operates them, referring to some mystery library is not accepted here, the code needs to actually be in your question. \$\endgroup\$ Jul 21, 2020 at 21:01
  • \$\begingroup\$ Suggestion: experiment with IR only, first. Once you have IR working and Arduino is transmiting IR data to serial, connect the motor and change the code to use the motor. \$\endgroup\$
    – mguima
    Jul 21, 2020 at 21:05
  • \$\begingroup\$ @mguima IR works perfectly fine in the above code I checked it via serial monitor \$\endgroup\$ Jul 21, 2020 at 21:26
  • \$\begingroup\$ @ChrisStratton The motor sheild is just a normal adafruit motor shield \$\endgroup\$ Jul 21, 2020 at 21:27
    \$\begingroup\$ @ReghunaathAA that may be the case, but the necessary technical information is still missing from your question. If you expect people to have the schematic of the Adafruit Motor Shield memorized, you need to be asking on the Adafruit Customer Support Forums (which are indeed a thing). Here on Electronics Stack Exchange, the asker of each question is required to provide key documentation. We aren't supposed to have to go hunt it down for you... and the goes double when your question failed to mention you were using an Adafruit design rather than an Arduino one. \$\endgroup\$ Jul 22, 2020 at 1:06
If you use the AFmotor library (adafruit shield) with IRremote, there is a conflict on TIMER2 (pin 3). If you do not use pin 9 for PWM issues in AFmotor, you can modify IRremoteInt.h in IRremote library by uncommenting the TIMER1 line instead of TIMER2 like below
// Arduino Duemilanove, Diecimila, LilyPad, Mini, Fio, etc
#else
#define IR_USE_TIMER1   // tx = pin 9  <--  uncomment
//#define IR_USE_TIMER2     // tx = pin 3 <-- comment
On my arduino UNO R3 it works well. With TIMER2, motors 1 and 2 where inactive. With TIMER1 all motors work.
Hope its helpfull for someone else
Is this the infrared receiver library you are using?
Compare the following code snippet from the IR receiver example they give with your code. Perhaps that's the issue?
#if defined(ESP32)
int IR_RECEIVE_PIN = 15;
#else
int IR_RECEIVE_PIN = 11;
#endif
IRrecv irrecv(IR_RECEIVE_PIN);
And is this the motor library you are using?
README.txt
This library is old and deprecated - and the hardware disconinued years ago. V2 of the shield uses i2c only and works with anything that has I2C support (e.g. all arduinos) without endless incompatibilities and porting requirements! :)
-> https://www.adafruit.com/products/1438
From the motor example they give, the motor is gradually slowed down before reversing it; rather than trying to instantly reverse at full speed.
Modified Controller
I've modified the controller a little:
  1. to slow down the motor before changing direction.
  2. to only command a new direction when the command changes the direction, i.e. it will ignore successive FORWARD commands or successive BACKWARD commands.
  3. to give more feedback about what it's doing.
decode_results old_results;        // ADDED to compare with previous results.
void setup()
  motor.run(RELEASE);
  Serial.println("Idle");                   // CHANGED to Idle.
  delay(1000);
void loop()
    if (results.value != old_results.value) // ADDED to test for change of command.
        old_results = results;              // ADDED to remember the command for next time.
        Serial.println("Slowing");          // ADDED to give feedback.
        motor.run(RELEASE);                 // ADDED to remove power from motor.
        delay(2000);                        // ADDED to let motor slow down before changing direction.
        Serial.println("Forward");          // ADDED to give feedback.
        motor.run(FORWARD);
        Serial.println("Backward");         // ADDED to give feedback.
        motor.run(FORWARD);
Possible Timer1 and Timer2 Conflict
I've been digging through the source code of the libraries and found that they both use Timer1 and Timer2 for some Arduinos. It may not be possible to use both libraries together with your Arduino. Perhaps you could modify the libary source code so that the IR Receiver and the motor use separate timers.
esp32.cpp
void IRrecv::enableIRIn() {
// Interrupt Service Routine - Fires every 50uS
    // ESP32 has a proper API to setup timers, no weird chip macros needed
    // simply call the readable API versions :)
    // 3 timers, choose #1, 80 divider nanosecond precision, 1 to count up
    timer = timerBegin(1, 80, 1);
    timerAttachInterrupt(timer, &IRTimer, 1);
    // every 50ns, autoreload = true
    timerAlarmWrite(timer, 50, true);
    timerAlarmEnable(timer);
irRecv.cpp
    cli();
    // Setup pulse clock timer interrupt
    // Prescale /8 (16M/8 = 0.5 microseconds per tick)
    // Therefore, the timer interval can range from 0.5 to 128 microseconds
    // Depending on the reset value (255 to 0)
    TIMER_CONFIG_NORMAL();
    // Timer2 Overflow Interrupt Enable
    TIMER_ENABLE_INTR;
    TIMER_RESET;
    sei();
AFMotor.cpp
#elif defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
    // on arduino mega, pin 11 is now PB5 (OC1A)
    OCR1A = s;
  • \$\begingroup\$ The ir works perfectly fine I checked it via serial monitor \$\endgroup\$ Jul 21, 2020 at 21:25
  • \$\begingroup\$ Have you written two separate programmes (one for the IR receiver and the other for the motor controller), and do they work as expected? \$\endgroup\$
    – tim
  • \$\begingroup\$ Yes, I did!! and irt worked fine @tim \$\endgroup\$ Jul 21, 2020 at 21:56
  • \$\begingroup\$ I'm wondering if motor.run(RELEASE); is out of place. From this example. there is a delay to allow the motor to slow down after releasing it. \$\endgroup\$
    – tim
    Jul 21, 2020 at 22:24
  • \$\begingroup\$ If I remove the ir part from the code, the motors start spinning so I guess that's not the issue here. \$\endgroup\$ Jul 22, 2020 at 13:56
