In color television systems back in the early days, people used to transmit color difference signals (Y-R) and (Y-B) along with Y, which is the luminance signal. My question is why are color difference signals transmitted rather than just two of the three R,G,B signals along with Y? What is the need for color difference signals rather than pure RG, GB, or RB?
12\$\begingroup\$ Compatible Color: The Ultimate Three-For-One Special by Technology Connections is highly recommended. He has a series of videos on TV technology. \$\endgroup\$– TransistorJul 21, 2020 at 20:27
2\$\begingroup\$ Due to compression technology in the era between analog and digital. Read up on YCbCr. \$\endgroup\$– winnyJul 21, 2020 at 20:51
\$\begingroup\$ @MoonzarinEsha Actually, you're right. You did mention that at the beginning. I saw RGB and missed the part about using only two pure colour signals along with Y. I will add some small edits to make less easy to skip over. \$\endgroup\$– DKNguyenJul 21, 2020 at 21:08
\$\begingroup\$ Modern digital uses luma+chroma as well for (most of) the same reasons. YUV420p means a full-resolution Y plane plus quarter-resolution (halved vertically and horizontally) U and V planes, which trades a small quality loss for a big reduction in bandwidth requirement. \$\endgroup\$– hobbsJul 22, 2020 at 14:47
\$\begingroup\$ One addition to the answers given: In the 1980s they planned some satellite TV system in France. Because it was clear that B&W TV sets would not be able to receive the satellite signal anyway, the system (which was not implemented later on) would have transmitted an R-G-B signal and not an Y-U-V signal. \$\endgroup\$– Martin RosenauJul 23, 2020 at 13:31
Since color transformations are a linear 3x3 matrix, so is converting RGB to YUV and back. Y is needed anyway for compatibility with B/W TVs, and Y signal consists mostly of G component, then mostly of R component, and least with B component, in certain proportions.
As RGB signals have full bandwidth from the camera, so does calculated Y. As human eyes are most sensitive to luminance than color, it makes no sense to waste bandwidth for direct transmission of R or G or B signals. The color signal must also be hidden inside B/W transmission.
Since the RGB to YUV is a linear matrix, you get 3 componets out if you put 3 components in. As the coefficents for calculating Y from RGB are known, the other two components are the ones that describe the other two components U and V.
The U and V components need to contain the rest of the info to calculate RGB, and since Y already contains most of G component, the U and V should contain mostly the R and B components, except the RGB parts that were already sent with Y. That's why the G component is not used. As the Y calculation was done with resistor dividers and analog amplifiers from RGB, you needed to minimize the circuitry, and inside a RGB to Y converter there already exist the RGB components and the weighted sum Y, so easiest thing to do was to also calculate R-Y and B-Y as they would result in larger signals than G-Y. So now the R-Y and B-Y are the signals that contain least luminance info and most color info. And since Y needs higher bandwidth and color info doesn't, the bandwidth of color difference signals R-Y and B-Y can be reduced even more, so that's why none of the R or G or B signals are directly sent.
1\$\begingroup\$ Nice answer. Interesting to note the reduced bandwidth results in some interesting effects and NTSC as "Never Twice Same Color" \$\endgroup\$ Jul 22, 2020 at 16:13
I'll address a couple of points briefly here. A full discussion of the analog color TV signal and the decisions that went into its design would fill a book.
When color TV was introduced, the broadcast format was already well established, with 6 MHz channels, using AM VSB for the video (Y) signal and an FM subcarrier at 4.5 MHz for the sound. They needed to find a way to add color information to this signal without using any additional bandwidth and without creating any incompatibility with BW receivers.
In order to accomplish this, they made two key choices:
- Use the HSB (hue, saturation, brightness) model to represent color images
- Encode the color information as a phase- and amplitude-modulated subcarrier
Since the existing Y signal is exactly equivalent to brightness in the HSB model, that means that only H and S need to be encoded on the subcarrier. They chose to encode hue as the phase angle of the subcarrier, and saturation as the amplitude of the subcarrier. The 0° phase reference is given by a "color burst" signal that was inserted into the horizontal blanking interval.
By carefully picking the frequencies used,1 and by suppressing the actual color carrier itself and sending only its sidebands, the new color information was effectively "interleaved" into the same spectrum used by the existing Y signal without creating visual artifacts for BW receivers.
Finally, getting back to your actual question, the B-Y and R-Y signals are just one way (the most common way) of expressing the phase and amplitude of the color subcarrier — you can think of them as the "rectangular" coordinates of what is really a "polar" signal. They are named that way because "blue" hue is defined to be close to 0° phase (maximum positive B-Y signal), and "red" hue is defined to be close to 90° phase (maximum positive R-Y signal). The "green" hue is close to 225° phase, which corresponds to the maximum negative values of both B-Y and R-Y.
1 In case you're curious, here are the details for NTSC. The original BW signal used frequencies of 15750 Hz and 60 Hz for horizontal and vertical scanning. In order to minimize the visual effects of any leakage of the audio subcarrier into the video signal, scan frequencies were reduced by a factor of 1.001 (to 15734.3 Hz and 59.94 Hz, respectively). This made the audio subcarrier exactly 286× the horizontal scan rate, which made any artifacts stand more or less still on the screen. This also puts the audio subcarrier in one of the "nulls" of the color subcarrier comb filter. In order to achieve the frequency-domain interleaving that I spoke of, the color subcarrier frequency needed to be an odd multiple of half the horizontal scan rate. They chose 455/2, which makes the color subcarrier frequency 15750/1.001*455/2 = 3.579545 MHz.
\$\begingroup\$ ....if you could point me to some tutorials or materials about this -> the B-Y and R-Y signals are just one way (the most common way) of expressing the phase and amplitude of the color subcarrier — you can think of them as the "rectangular" coordinates of what is really a "polar" signal. They are named that way because "blue" hue is defined to be close to 0° phase (maximum positive B-Y signal), and "red" hue is defined to be close to 90° phase (maximum positive R-Y signal) \$\endgroup\$ Jul 21, 2020 at 22:11
\$\begingroup\$ I don't have a specific reference for you, but if you plug the phrase "NTSC color phase angles" into your favorite search engine, you'll get all kinds of additional information. \$\endgroup\$ Jul 21, 2020 at 22:26
\$\begingroup\$ This video - Why is TV 29.97 frames per second covers much of the same information, for learners who prefer video to print. \$\endgroup\$ Jul 22, 2020 at 14:45
\$\begingroup\$ I'm skeptical of your use of the term "HSB" and whether there's any historical context/basis for it. Generally HSB means a completely different kind of colorspace than YUV, where "brightness" does not match luminance (Y) or anything perceptual but is just a sum/mean of the RGB color channels, and it's usually associated with backwards image editing software from the 90s. \$\endgroup\$ Jul 23, 2020 at 17:30
You need Y (R+G+B) aka Luminance, to represent the monochrome signal, both for compatibility with B+W television, and because it is the most important part of the colour TV signal, requiring the highest bandwidth.
You need two other signals to convey three colour channels ... but why U and V rather than R and B? (not G, because Y is mostly G anyway)
Because, except for the most brightly hued colours in the image, there is less information in U and V than there would be in R and B : indeed for a grayscale there is no information at all in the colour difference signals, and for pastel colours, very little. Then R and B signals would be mainly duplicates of the G (or Y) signal, while U and V are low amplitude (and do relatively little damage to the monochrome Y signal they are layered on top of)
Reducing the auxiliary information to be transmitted, allows transmission with less signal space.
Experiments showed the bandwidth of the colour difference signals can be reduced to about 0.5 MHz (vs 5.5 MHz for the luminance channel in a 625 line system) without doing too much damage to the image quality.
\$\begingroup\$ ....I would appreciate if you could point me to some tutorials or materials about your answer. \$\endgroup\$ Jul 21, 2020 at 22:13
\$\begingroup\$ Color difference bandwidth would need to be much higher than 0.5Mhz. On a 40-column display, each character is about 1 microsecond wide, so a bandwidth of 0.5Mhz would allow one cycle every two characters. \$\endgroup\$– supercatJul 22, 2020 at 18:49
\$\begingroup\$ @supercat That's why subtitles weren't full colour on broadcast television. Ceefax/Prestel etc could generate captions locally avoiding the bandwidth limits. \$\endgroup\$ Jul 22, 2020 at 18:53
\$\begingroup\$ @BrianDrummond: Computers for NTSC and PAL could produce composite video output which allowed 40 characters per line to be independently colored relatively cleanly. That wouldn't be possible if chroma bandwidth were as bad as what you say. \$\endgroup\$– supercatJul 22, 2020 at 19:12
\$\begingroup\$ @supercat the modulators they used did have higher chroma bandwidth : not all systems did. \$\endgroup\$ Jul 22, 2020 at 19:28
As others have explained in detail, YCbCr is basically a compatibility hack for black-and-white TV combined with a way to send chroma information at a lower resolution than luma information to make efficient use of available bandwidth.
What others haven't mentioned, which I think you'd benefit from, is Xiph.org's A Digital Media Primer for Geeks, which starts into video at 16:00 (though the first mention of what you specifically care about begins around 17:23 if I remember correctly).
It covers things like interlacing, gamma, YCbCr, subsampling, and various other things you want to know in order to be effective in doing self-directed study.
\$\begingroup\$ Not quite accurate, YCbCr has nothing to do with lower chroma resolution. You are confusing YCbCr which is a color space with chroma subsampling methods like 4:4:4, 4:2:2, and 4:2:0, which means how the of chroma is sampled compared to luma. YCbCr is a digital component version of YPbPr analog component video that is traditionally sent over 3 RCA jacks. It does have its roots in YUV analog signal, but UV cmponents have different scale than PbPr. And PAL does transmit in YUV, but NTSC transmits a 33 degrees rotated version of YUV called YIQ. \$\endgroup\$– JustmeJul 23, 2020 at 16:43
\$\begingroup\$ Good point. Would clarifying it to "the use of the YCbCr family of color spaces enables both a compatibility hack for black-and-white TV and encoding the chroma information at a lower resolution than the luma to make more efficient use of available bandwidth" be sufficient? (I used "YCbCr" because I was told that it's commonly used to refer to both analogue and digital applications and Wikipedia agreed.) \$\endgroup\$– ssokolowJul 24, 2020 at 16:43
