We know that using T-Flip Flops in a cascaded manner(something like ripple counter) allows us to divide the clock frequency by a factor of \$2^{n}\$ where \$n\$ stands for the number of flip-flops. Now, Suppose I want to divide my original clock frequency by a factor of 3 or by 9? What can I do to achieve this?
My progress: Suppose we want to divide the given frequency by a factor of 6. Then, I thought that we can achieve our task by connecting the counter circuit and then adding some combinatorial circuit to change the clock only when 3 counts are done. This way whenever 6 counts are completed, one output cycle will complete.(Look at the circuit below):
But how do we do when we want to divide the clock frequency by a factor of 3 or 5 or 9?
    \$\begingroup\$ If you don't care about duty cycle, just toggle after 2 counts, then after 3 counts, then 2 counts again and so on. This will divide the frequency by 5. For this, you will need not only a combinatorial circuit, but a memory element also (a flip flop?) to keep track of whether the current count limit should be 2 or 3. \$\endgroup\$
    – AJN
    Jul 22, 2020 at 3:33
    \$\begingroup\$ Suppose we want to have a factor of 3. Then? \$\endgroup\$
    – Puneet
    Jul 22, 2020 at 3:39
    \$\begingroup\$ Like whenever three clock cycles complete, my one output cycle will complete. \$\endgroup\$
    – Puneet
    \$\begingroup\$ For three use 1 count and 2 count alternately ? \$\endgroup\$
    – AJN
    Jul 22, 2020 at 3:41
    \$\begingroup\$ Okay. But I think we won't be able to maintain a duty cycle of 50% then. Right? \$\endgroup\$
    – Puneet
    Jul 22, 2020 at 3:42
4 Answers 4
Use added logic to capture counts as they appear at the binary counters outputs. The LSB is 1 if high. The weight of the bits is 1, 2, 4, 8 for a 4 bit counter. A count of 9 means 1 and 8 are high, 2 and 4 are low. Use and or nand gates on these pins to reset the counter each time it has a count of 9, or a count of 8 if asynchronous reset, as 0 is part of the count.
As long as the clock pulse is running it will repeat the same count endlessly.
Because 0 is part of the count, the counter will have one more state then the counters value.
    \$\begingroup\$ This is correct. But I wanted to divide my clock frequency by arbitrary number. From your explanation. From what I understand, your suggestion would yield an answer which would have double the required time period. \$\endgroup\$
    – Puneet
    Jul 22, 2020 at 3:45
    \$\begingroup\$ For example I want my output to have a duty cycle of 50% and when three clock cycles complete, then one output cycle should complete. \$\endgroup\$
    – Puneet
    Jul 22, 2020 at 3:48
    \$\begingroup\$ To make a counter have an arbitrary value feedback is mandatory. If you have time constraints then double speed the clock. \$\endgroup\$
    – user105652
    Jul 22, 2020 at 3:49
    \$\begingroup\$ Okay. Doubling the speed of the clock will work(given we can do that). By the way, I am new to electronics, what is arbitrary value feedback? \$\endgroup\$
    – Puneet
    Jul 22, 2020 at 3:51
    \$\begingroup\$ 50% duty cycle is impossible for odd numbers, unless you use a FF to divide by 2 to get 50%. \$\endgroup\$
    – user105652
Your flip-flop divider is creating a binary counter: the input is the one's place, the first FF gives the next binary digit, etc.
The key is that this type of counter resets automatically, e.g. after 16 cycles using 3 FF's (4 bits). You can also reset the counter earlier to create an arbitrary divider; if you enable a (synchronous) reset when that counter has a value of N-1, the top bit (that changes) will yield a rising edge every N cycles.
Note that this output will not have a 50% duty cycle, unless N is a power of 2. You can improve this with some additional decoding, outputting a 1 (only) when the counter is N/2 or greater. If N is odd, you will need something like a PLL to achieve 50%.
Question
How to divide frequency by an arbitrary number?
Answer
By a octal or decade counter.
decade and octal counter
References
(1) CD 4017 CD4022 CMOS Frequency Counter Dividers - TI
(2) Digital Counters - Wikipedia
(3) Ring Counter (Including Johnson Counter) - Wikipedia
(4) Johnson Counter - Electronics Course
(5) Robert Royce Johnson (Johnson Counter) - Wikipedia
(6) Robert Royce (Bob) Johnson - The Salt Lake Tribune
There is a wonderful summary of division methods using only JK flipflops without other gates, published in 1968(!) as "Gateless Scalers with J-K Flip-flops" by P. A. Neeteson of Philips Central Application Laboratory, Eindhoven, Netherlands. The article is long out of print, but I obtained a photocopy through the British Library.
