Just received a switch mode power supply from china and wanted to double check everything before applying power - The screw terminals coming from the cage have Live, Neutral, Ground marked with a sticker but given the fact that the Made in China label itself is misspelled ("MAED IN CHINA") I have little faith in the labels.
While ground has continuity with the external cage, I noticed that the terminal marked Neutral is connected to the internal fuse on the circuit board while to the best of my knowledge the fuse should be connected closest to the live wire - Is this just a convention or does it add safety? and can mixing Live and Neutral make a circuit less safe assuming everything is still properly enclosed in the earthed cage?
  • \$\begingroup\$ Can you link to the power supply datasheet? Will this be a permanent installation or will it have a mains plug? \$\endgroup\$ – Justme Jul 22 at 4:49
  • \$\begingroup\$ Will be connecting a mains plug with additional fuse and switch inlined inside the external housing - there is no datasheet available to me. \$\endgroup\$ – norlesh Jul 22 at 4:54
  • \$\begingroup\$ Any other link to the power supply to see it? \$\endgroup\$ – Justme Jul 22 at 4:58
  • \$\begingroup\$ lhgroup.en.made-in-china.com/product/YSnJdxAWVlRV/… \$\endgroup\$ – norlesh Jul 22 at 5:02
Since you will be using an earthed mains plug, and as you have polarized mains plugs in AU, I would connect it like it says on the label. However, as most power supplies like computers supplies only have one fuse, and they are used in countries where you can connect mains plug in either orientation, so the live and neutral are not guaranteed to be in certain way, it makes little difference which way you connect it, as the input should be symmetrical otherwise.
| improve this answer | |
