So, let's imagine that you've got a superconductive voltage source (e.g. a wind turbine) hooked up to a loop of superconductive wire to form a circuit. Kirchoff's Voltage Law states that the sum of electrical potential differences around a circuit must be equal to zero; however, in this scenario, you've got a voltage source hooked up to a circuit with no apparent voltage drops. In analysis of ideal circuits, this is where you add in parasitic resistance, but if everything in the circuit is composed of superconductors, their resistance would be zero, right?
Here's an image of the circuit (I apologize for low-quality because I made it in MS Paint because I don't have any professional circuit-drafting software, and I can't find the symbols used to designate things as being superconductors):
Obviously, there has to be something screwy going on here; where is the voltage dropped? Is there some sort of exotic property of superconducting materials that comes into play in these situations?
