I'm trying to switch a small 230V AC motor using an Arduino Uno, but I'm having same problems due to interference on the relay (so the Arduino itself is not a problem).
Sometimes the module create voltage/current peak on the wires going to the Arduino, and it reboot or sometimes stops running the sketch until I unplug the power to the board and connect it again.
Looking the signal on the oscilloscope I see something like that
and sometimes the peak are in very short periods
I tried to add capacitors or diods in different configurations, but nothing really solved the problem, in some cases it only appear more rarely.
The relay module I'm using are the standard Arduino-type optoisolated ones, already with back-current diod and optical isolation, so I thought it should work without any extra circuit, but apparently it is not, or maybe the module is broken?
What should I do to fix the problem?
