I am planning to build 4 LED-strips using two different 'white' settings (1+1 strip x 4). The LEDs will be driven by a 24V constant voltage dimmable RGB-DALI driver (up to 5A per channel). My idea is to control the two strips (2700K and 5000K) using the R and G channel and the PWM mode for dimming. I drew and calculated the necessary circuit:
The parts are both from this series. (Warm white LED 2700K, Cool white LED 5000K). The resistors are standard 1206 SMD. My calculations for a target illumination of ~500lm yield (for 2700K):
\$ 20 \times 23...26.5lm = 460...530lm\$
In order to satisfy the 24V I need to split the strip into 4 paths with 5 LED each.
\$ 5 x V_{led} = 5 \times 2.8...3.3V = 14...16.5V\$
\$ R_{pre} = \frac{V_{in} - 5\times V_{led}}{I_{LED}} = \frac{24V - 5\times 2.8...3.3V}{60mA} = 125...166\Omega\$
Choosing a 180\$\Omega\$ resistor gives an effective current of
\$I_{path} = 41.6...55.5\leq I_{forward} \$
For all four strips I would come to
\$ P_{max1} \sim 4W \$
Now my questions:
- Are there more parts (filter, overvoltage protection) necessary to build an LED application? It seems too simple for decent light source.
- Is my calculation correct? (Heat and prematurly degradation should not affect my circuit, since I am under the recommended forward current).
- Can aging both in the driver and the LEDs produce a state where the forward voltages cant be produced?
- Should an LED in one path fail the entire path is lost, but no current is induced in the other paths since the driver regulates the draw. Correct?
