People who have hard times when they try to understand feedback amplifier oscillators probably see the light if they can handle an audio system which has a mic, an amplifier and a speaker. Very soon they learn that the system starts to whistle or roar if there's too much gain or the mic is too near the speaker.
The audio system has mathematically the same structure as your diagram. The amp gets its input from the mic. The mic outputs the sum of different audio sound sources, only converted to millivolt level AC. If the mic is in the hands of a singer the main components of the amp input are the voice and the feedback that the mic picks from the speaker.
If it happens that the amp amplifies the picked speaker sound to louder than the picked sound was originally the oscillation starts. The singing or actually any noise starts the oscillation. Very quickly the system whistles or roars with the full power that the amp can output. The oscillation happens at a frequency which fullfills the Barkhausen criterion. The phase shift in the loop is N*360 degrees only at certain frequencies which vary radically if the mic is moved. That's because the feedback route has a delay due the speaker-mic distance.
If the amp amplifies the picked feedback sound to the same level than the original the oscillation can be noticeable, but the level of the whistle doesn't grow nor diminish. The phase condition must still be true, so only certain frequencies can stay ringing around the speaker-mic-amp-speaker loop. Audio people say the system is at the edge of the feedback. Moving the mic say 10 cm can change the loop gain or phase shift so that the just noticeable oscillation dies away or escalates to full roar.
If the amp amplifies less than the route amp output-speaker-mic-amp input attenuates everything which travels around the loop dies away.
Oscillator circuits have loop gain > 1 to make the starting of the oscillation possible. The feedback circuit has a filter which is designed to make the oscillation possible only at a certain frequency.
To prevent the oscillation to escalate to the max output power of the amp there's in in many oscillators a special stabilization circuit which reduces the loop gain as the output power increases. The circuit is a must if a pure sinewave is the wanted output signal. The same happens in audio systems manually. An experienced singer learns soon to move the mic to a better (=lower feedback) place if he hears a sign of starting oscillation.
