How would you suggest charging 2S lion pack from any USB port?
One thing is to Enumerate the USB port and decide how much current we can draw. There are ICs for this, but I would prefer complete module with the circuitary already implemented.
The next thing is proper charging profile for the Li-On (CC/CV), balancing those 2 cells and if they cannot be charged independently then we would need step-up from 5V to 8.4V.
What would be simplest approach to this?
  • \$\begingroup\$ Buying a module seems the only course of action then. Shopping questions are off-topic by the way. \$\endgroup\$ – Andy aka Jul 24 at 12:46
You are confusing/conflating two different things. I read between the lines that you want to charge your batteries "most optimally", and thus want to determine the port power capability. The method to charge the 2S battery geometry is an entirely different question.
First, you don't need to "Enumerate the USB port" (more accurately, you have no control over this, the port will be enumerated from host USB software if your device supports USB data protocol) to "decide how much current you can draw". Port enumeration has nothing to do with power available over VBUS supply.
If you mean the classic USB-A port, you can start with testing if it has BC 1.x support (using appropriate ICs that have the built-in BC algorithm). If no success, you can switch to QC method, but again, this would apply to "charging ports" only, no data transfer.
If you want to outsmart and want to determine if the Type-A port is USB2 or USB3 (and thus has guaranteed 500 mA or 900 mA), there are simplified methods to make this distinction besides having full USB3 interface engine and condition your current intake depending on the mode it gets enumerated into.
You should understand that the USB port power is not bounded on upper side by USB specifications. The spec require "at least" 500 or 900 mA from classic USB ports, with no "max". The power is bounded by manufacturers to ensure safe fire-proof operation of USB ports under every possible condition, including partial "short".
Yet another method is to gradually increase the load and monitor resulting voltage. Charging ports must provide gradual decrease ("soft") in supplied voltage when the load approaches port design limit. Again, do this with a reasonable assumption of connector pin limit, which is usually under 2A.
If you are thinking of Type-C ports, everything is built into Power Delivery protocol, so you must use proper IC that supports PD, understands Discovery methods, and reports to your device the uncovered link power capability. Again, this process occurs completely outside the USB data enumeration process.
Regarding the way to charge the 2-S battery configuration, your proposition to "charge the cells individually" will likely be cost prohibitive, since you will need to employ a complex system of high-current (low milli-Ohms grade) switches, which are expensive. So the only meaningful solution is to boost the VBUS voltage to about ~9V and use a standard 2-S balanced charger IC.
| improve this answer | |
I think using CC,CV step-up will do the job along side with battery protection and balancing. Also step up can limit input current.
If you want to keep things simple, I would recommend using two TP4056 lithium ion battery charger ICs, which manage the charging profile. Have a look at this link. You can You will need to electrically separate the series connection between the batteries during charging and change the value of the charge resistor so you don't exceed the maximum current rating of the USB port.
You could also use two separate USB supplies, e.g. phone chargers, in which case you could stack the TP4056 chargers, i.e. connect one to one battery and the second to the other battery. In this case you won't need to remove the series connection between the batteries.
  • \$\begingroup\$ Hi, thanks for suggestion. I already have those modules and did replace the prog. Resistor to constrain each module to 200mA. Could you please suggest how could I separate the series connection between the batteries? \$\endgroup\$ – Tomáš Viks Pilný Jul 24 at 13:13
  • \$\begingroup\$ Are there separate 18650 cells or is it a sealed unit? \$\endgroup\$ – mr_js Jul 24 at 13:16
  • \$\begingroup\$ Separate. I simply got 2 separate cells and now trying to get everything together \$\endgroup\$ – Tomáš Viks Pilný Jul 24 at 13:17
  • \$\begingroup\$ In that case, you could use two separate USB supplies (see modified answer). \$\endgroup\$ – mr_js Jul 24 at 13:46
  • \$\begingroup\$ What do you mean separate? I would like to be user friendly - one port, one cable. I have those charger modules you suggested and I like the idea of series separation, but i don't know how to do that. The complete pack needs to remain in series for powering the device. \$\endgroup\$ – Tomáš Viks Pilný Jul 24 at 13:54
