I'm building a compact portable console that is going to use a 500ma charger board from Adafruit and possibly a 5v 1a boost as well. Past experience has taught me the chips on those little circuit boards can get quite toasty.
There is not a lot of clearance in my current design between the top of the breakout boards and the flat underside of the polymer battery.
What would you recommend for clearance between the two?
Alternatively, is there a way I could implement some sort of nonconductive barrier to prevent them from touching and exchanging heat?
Thank you in advance, I've done mods before but this is my first time playing with case design.
