I just did some calculations, and to me it seems that the induction motor only works when the rotors coils have finite resistance:
I will show that for a single conducting loop, whose current is driven by change of flux due to the exterior magnetic field, the torque on the loop will be zero when the current is zero, and when the voltage is zero as well.
I assume that the stators coils produce a rotating magnetic field. For the sake of the question, I I'm switchting to a rotating frame of reference, that rotates with the same frequency, by which also the rotor rotates. In this system, the only thing that is moving is the rotor (unless it's rotating with the same frequency. I assume that there is a "slip", so in the reference frame of the outer magnetic field, the rotor rotates to the right). I'm aware that a rotor doesn't consist of only one loop, but of many, and that they are arranged in different angles. I still think that for the sake of the question, it's enough to draw one loop.
In the 2nd picture, the voltage induced in the loop BY THE OUTER ROTATING MAGNETIC FIELD ALONE is at max, because the change in magnetic flux reaches an extreme point when the magnetic field lines are perpendicular to plane of the loop. The voltage drives the current in the loop. Because the loop is an inductor itself (it creates a magnetic field as well), the current is behind the voltage by 90 degrees. That means the current is at max in reverse direction in the first picture. However, In the situation of the first picture, there isn't any torque acting on the rotor, because the torque generated by Lorentz forces acting on the charges sums up to zero. In the 2nd picture, current would generate the maximum possible torque. But here (since current is behind voltage by 90°) the current is zero.
Question: Is it wrong to just look at the 2 cases that I described here? Or do we in general need to introduce resistors into the rotors circuit, to change the phase-shift between voltage and current?
    \$\begingroup\$ @MikeWaters God I hope so. \$\endgroup\$
    – DKNguyen
    Aug 1, 2020 at 15:50
    \$\begingroup\$ I don't understand the downvote. @MikeWaters ideal inductors are usually modelled without resistance. For somebody who doesn't have mutch clue, my first guess was that coppers resistance of the copper isn't big compared to inductive reactance of the moter. Besides that, the question here deals with the question wether an induction motor with lossless windings can work in principle. \$\endgroup\$ Aug 1, 2020 at 16:07
    \$\begingroup\$ @MikeWaters one of the degrees of freedom in designing induction machines is the rotor resistance. Machines can have rotor resistance introduced deliberately, because it gives higher starting torque, at the cost of more slip and reduced efficiency. I think it's valid to ask what happens if you should go all the way the other way -- even if it's just in theory. \$\endgroup\$
    – TimWescott
    Aug 1, 2020 at 20:08
    \$\begingroup\$ "I assume that there is a "slip"" - why? \$\endgroup\$ Aug 1, 2020 at 20:30
    \$\begingroup\$ @BruceAbbott because it's the usual mode of operation for an induction motor. The other steady-state possible is that there is no slip at all, but this not an interesting steady state, because nothing happens. \$\endgroup\$ Aug 1, 2020 at 22:18
Using the usual equivalent circuit, the electrical power converted to mechanical power is calculated as the power dissipated in R2x(1-s)/s where R2 is the rotor resistance. That would seem to require a finite rotor resistance. The rotor resistance is quite small in most induction motors, but the other impedances in the equivalent circuit are also quite small, so the rotor resistance is not small in comparison.
If you look at the torque vs speed equation Torque-Speed Equation for Induction Motor, it looks to me that it does not fail if R2 = 0.
You may also want to look at When load increases in rotor of induction motor how does stator draws more current? for more detail about the equivalent circuit.
As commented by @MikeWaters, there is not much reason to pursue this unless you are interested in a superconductor rotor.
Re Comments
Increasing the rotor resistance results in higher slip at a given torque as shown below. Resistance can be increased and decreased by changing the rotor bar size and material and be connecting external resistors through slip rings. The highest slip without external resistance that is commonly offered is about 13% at rated torque. Slip in the area of 1.5 to 2 percent seems to be available with aluminum rotor bars. Copper rotor bars must be able to provide slip a bitbelow 1.5%.
The equivalent circuit is used in motor design, but the design process is a lot more than that. With most motors, more than one equivalent circuit or more branches in the rotor circuit are needed to model changes in the rotor resistance when the slip is high. The simple circuit works only for rotor bars that do nor extend very far into the rotor from the surface. In order to provide higher torque at high slip, the rotor bars are extended more deeply or split into a surface part and a deep part.
If the motor is intended only for use with a VFD, the motor could be designed with big copper rotor bars close to the surface. That seems to be the strategy used for the early model Tesla cars.
An induction motor is not supposed to be able to develop torque without slip, but I don't know what happens as the torque vs. speed curve becomes vertical. That seems to be what will happen as R2 approaches zero.
Calculations
The following shows the results of progressively reducing R2. T1 represents a curve for the equivalent circuit that I believe represents a motor that was actually constructed. I don't remember where I got the data. T2 shows the "normal" effect of reducing rotor resistance, the peak torque remains the same but occurs at a lower slip. T3 shows a slight rise in peak torque but a more drastic reduction in torque on the high-slip side of the peak. T4 and T5 show the peak torque falling with reduced R2. Per unit values of R2 are 1, .7, .23, .14 and.02 for T1, T2, T3, T4 and T5 respectively. The equivalent circuit used omitted the magnetization branch.
  • \$\begingroup\$ Your 2nd paragraph is misleading to me: Did you mean to write " "it does not fail if R2 = 0"? In general your answer seems to be that for R2 = 0, there isn't any torque. Do I understand you right at this point? \$\endgroup\$ Aug 1, 2020 at 17:04
  • \$\begingroup\$ Yes, I corrected that. Thank you. \$\endgroup\$
    – user80875
    Aug 1, 2020 at 19:14
  • \$\begingroup\$ What do you mean by "doesn't fail". The equation still makes sense, but the outcome would be that T= 0. I'm nitpicking on this, because that's still a part of your question which otherwise would be in dissagreement with the previous paragraph. If this is understood, then my question is answered. \$\endgroup\$ Aug 1, 2020 at 19:20
  • \$\begingroup\$ I believe that you get something other than T = 0. I am not sure if the value is reasonable, but I think it is. \$\endgroup\$
    – user80875
    Aug 1, 2020 at 19:34
    \$\begingroup\$ @mkeith you're right, it won't stop working, instead times Tc become infinite. Superconductor coils are perfect EM shields in that their enclosed net flux cannot change. A superconductor ring should behave like a PM magnet: synchronous motor with torque and lag-angle, and zero slip. But also I suspect that the starting torque will be zero, and the zero-ohm rotor will never start up (it might just vibrate back and forth, a net zero torque over time.) \$\endgroup\$
    – wbeaty
    Aug 1, 2020 at 21:31
Superconductors are impervious to magnetic fields, so if you have a superconducting rotor no fields lines will enter it. (or pass through the apertures of the squirrel cage)
With no field lines in the rotor there will be no torque.
you could possibly get it running synchrounosly as a variable reluctance motor. but you'd need a way to start it, and there wouldn't be much torque available to keep it running.
  • \$\begingroup\$ Isn't a superconducting coil similar to a permanent magnet in terms of flux? So a superconducting coil could conceivably be used as a magnet in a synchronous motor, as long as the coil is excited somehow? \$\endgroup\$
    – user57037
    Aug 2, 2020 at 19:41
    \$\begingroup\$ well,a loop, not a coil yes it could be magnetized before it becomes a superconductor then the the magnetism would be "frozen in". \$\endgroup\$ Aug 2, 2020 at 22:09
  • \$\begingroup\$ So if you had a super-conducting rotor above its superconductor temp and let it spin up to speed, then cooled it down below its super-conducting temp, it would maybe become a permanent magnet synchronous motor (or maybe not...). \$\endgroup\$
    – user57037
    Aug 2, 2020 at 22:49
  • \$\begingroup\$ I think that would work. \$\endgroup\$ Aug 2, 2020 at 23:34
