I have two SoCs that are mounted on a the same carrier board using SODIMM connector. The two SoC are mounted very close to each other, the entire carrier board is smaller than 15x15 cm
I need to connect the two computers to each other using cross over Ethernet so they can talk back and forth. Given that I am not using any RJ45 or any sort of cables and the Ethernet pins of SoC-A is being directly connected to the Ethernet Pins of SoC-B using traces on the PCB, do I need to use any magnetics? Can I just directly connect the SODIMM pins to each other ?
Distance between the two SODIMM pins are about 1 or 2 cm
