I have the following magnetic field measuring setup:
  • Picoscope 2204A
  • 16m wounded up bell wire connected to tip and ground clip as search coil antenna
Now I want to enhance the sensivity for 50Hz to 1MHz.
I have thought about the following things:
  • Picoscope measuring sensivity is near white noise, so an osciloscope amplifier wouldn't have an effect I think.
  • Maybe replace the bell wire with a litz wire with many strands like in Coaxial cables? RG58?
  • \$\begingroup\$ You didn't mention the magnetic field source you are trying to detect. \$\endgroup\$
    Commented Aug 6, 2020 at 8:21
  • \$\begingroup\$ I measure All sort of consumer electronics like notebooks, powerbanks, smartphones... \$\endgroup\$ Commented Aug 6, 2020 at 8:22
  • \$\begingroup\$ What are you hoping to achieve? \$\endgroup\$
    Commented Aug 6, 2020 at 8:23
  • \$\begingroup\$ Send back the electronics with too much emission to preserve my nerves. \$\endgroup\$ Commented Aug 6, 2020 at 8:38
