I'm considering using one of the following LDMOS FETs as an RF amplifier:
- AFM907N (8W)
- AFT05MS031NR1 (30W)
- AFT05MP075NR1 (70W)
The datasheets provide \$Z_{source}\$ and \$Z_{load}\$ metrics for some frequencies (as below), but not for all frequencies they support and not for the frequency that I'm looking for (146MHz center)---though the FETs do support that frequency. If I can get the \$Z_{source}\$ and \$Z_{load}\$ at 146MHz, then I could use those numbers to create a matching network (L/Pi/Tee).
- If you were to match this component to 50 Ohms, how would you do so?
- What information from the datasheet do you use to calculate a matching network at 146MHz?
- Is there an online calculator (or some formula) into which I would plug in that information?
- If it helps you answer the question, the Icom IC-9700 uses the AFT05MP075NR1:
- The service manual PDF is available here
- Page 8 (2-2) has a photo of the components labeled "PA-A"
- Page 87 (10-14) shows the TX amplifier pipeline schematic in orange (RX is green)
Here is NXP's test fixture from the AFM907N datasheet on Page 11:
