I'm not entirely sure how to choose power supply for bldc motor. I have 2 80wat motors with controller (black box, i cant find out what inside), but stall current for both of them can be close to 80A. Controller has 3 wires conected directly to motor. Can I buy simple power supply for 24V and install in series diode for 80A like in this article https://www.heliosps.com/dc-power-supplies-dc-motors/? This would be enought for protecting from damage and also make proper condition for this motors? Or maybe use additional shunt regulator? Thanks for your help.
80W motor with current of 40A and supply of 24V? Makes no sense at first look, but this 40A stall current is measured at speed = 0 (rotor locked), this is not a working range of the motor
Your driver works as buck converter, so you don't need 2 x 40A x 24V supply power. You should use the nominal current of the motor, not the stall current for proper supply calculation, the short term high current can be supplied by a capacitor bank. Look also for max. peak motor current, not a stall current.
    \$\begingroup\$ Datasheet provide nominal and stall currnet. Also do I need special power supply for that? Maybe can you suggest specific product? What about protection? \$\endgroup\$
    – Toriam
    Aug 7, 2020 at 13:53
    \$\begingroup\$ You didn't provide any data about motor and driver, only a useless 3rd party link. \$\endgroup\$ Aug 7, 2020 at 15:33
    \$\begingroup\$ Driver is EPOS4 50/15 from maxon and motor is EC-i 30 and EC-i 40 from maxon also \$\endgroup\$
    – Toriam
    Aug 8, 2020 at 19:00
    \$\begingroup\$ @Toriam Sum the two noninal currents, add some reserve and you get it. I guess somewhere in the range of 5A. \$\endgroup\$ Aug 9, 2020 at 11:03
    \$\begingroup\$ Do i need additional protection? Like a diode in series? \$\endgroup\$
    – Toriam
    Aug 10, 2020 at 16:47
