I have a PCB with an Atmega328 and have been programming it using FTDI Friend (FT232RL Chip Adapter). The adapter connects to a 6 pin FTDI header on the PCB. I want to connect the FTDI Chip Adapter to the board using a USB-C Connector instead of the 6 pin header. This will allow me to connect through the housing via the USB-C connector to not only provide power but to also program it without having to take the assembly apart to accesss the 6 pin header. I am not using any of the advanced capabilities of the USB-C, simply the reversible features of the pins.
Question: Can I simply connect the 6 wire output from the FTDI Friend to the the USB-C as shown below? Connecting opposite pins on the PCB to allow connector to be flipped?
It may be a simple question, but reading a lot about USB-C made me question myself.
I know it is overkill using USB-C, but being flippable will be a benefit to the user.
Cable to be used:Cable
USB-C to be used: USB-C Connector
Diagram
Schematic
UPDATE 8 Aug
Thanks for your thoughts. Yes, being incompatible with USB-C standard could cause damage.
The reason I want to use the USB-C for my product is not technical: The availability of high end power cables - cloth braided, colors, nice connectors. This plus the modern/reversible connector.
Reading the USB-C data sheet, could I avoid accidental damage by only using GND, VBUS, D-, D+ as shown Figure 4 page 7, USB 2.0 TYPE C Pinout?
USB Datasheet
I would not be using pins CC and VCONN connections. I would short the two D+ pins and the two D- pins on the PCB per paragraph 1.3.1 page 4.
I would not connect FTDI RTS used to reset, would have to reset with a button on the board, unless there is a pin I could use for RTS and be compliant with the USB C spec.
This is shown in updated graphic below.
Question: Are FTDI signals RX and TX the type to be sent on pins D- and D+ ? Would sending them on these pins be complaint to the standard?
Update to not violate USB C spec
  • \$\begingroup\$ I mean...you could...but what happens when someone mistakes it for a USB-C? If I really wanted a reversible header I would use a double row header and mirror the connections. It literally does the same thing. If you're just using the USB-C as a hunk of metal you don't even need to follow the pinout labels as long as it is mirrored. \$\endgroup\$
    – DKNguyen
    Aug 7, 2020 at 21:28
  • \$\begingroup\$ Why would you use the USB-C connector in a non-standard way? If someone comes in and there is an USB-C connector, someone will plug in a standard USB-C connector and something can get damaged. People are not accustomed to things that fit together but must no be connected together. For example, you would not use mains plugs for conneting spekers either, what do you think? \$\endgroup\$
    – Justme
    Aug 7, 2020 at 21:33
There are two parts to this, electrical and logical
Electrically speaking, the (initial) signal voltage of the legacy USB data pair is comparable to that of 3v3 logic. So in terms of causing damage the main question is if your MCU serial port is operating at 3v3 or 5v. Many more modern MCUs would run at 3v3 which you would regulate inside your device from the 5v input, but the ATmega is in an older process which cannot quite officially run at full speed with only 3v3 supply, so there's a good chance you are using logic voltages that would be outside the USB spec. And even if your MCU were driving its transmit with 3v3 levels, that doesn't necessarily mean you might not accidentally get a USB-UART cable which gave 5v output on its transmit - many (though not all!) MCUs are explicitly tolerant of mild overvoltage on their UART pins (eg the pins will have a "5v tolerant" legend in the data sheet). USB devices may often be robust, but do you want to count on that?
Logically speaking of course, your UART signal look nothing like any sort of USB at all. Any USB host to which this is accidentally connected would likely thrash in confusion for a bit every time one of the data lines changed in a way that falsely suggested a USB low or full speed device had just been plugged in. That's likely to create a lot of log file noise, and maybe in unlucky cases some system hiccups, but hopefully nothing more.
Generally speaking, borrowing a connector that everyone recognizes as having a particular purpose to use for a very different purpose is not a good idea. Doing it in a way that won't "fry" something accidentally connected is better than doing it in a dangerous way, but still...
  • \$\begingroup\$ That pretty much settles it. The most I could do with a USB-C would be to only use the VBUS and GND pins, which does seem silly. I just need to find another reversible connector as Tom suggested. Thanks to you all for your answers. \$\endgroup\$
    – BlueSky
    Aug 8, 2020 at 16:55
Firstly I would strongly advise against this - it will be completely electrically incompatible with USB-C, meaning accidentally connecting it to a USB host or device would be potentially damaging to both.
There are other reversible connectors available, including simple dual row pin header, which would allow physical identification that it is not intended to be used with a USB-C ecosystem along with mechanical prevention of doing so.
If this is more than just a personal hobby project - i.e. you plan to make a product that others will use - then I can't stress strongly enough that this would be a bad idea.
If you wish to continue, yes you can repurpose the connector as shown. Again you would need to make sure you only connect it to something expecting your completely different usage.
The only thing you could change is to connect CTS to the Rx1+/Rx2+ pins for extra flexibility. You could add a simple jumper of you want it connecting to GND.
  • \$\begingroup\$ Thank you for your comments. I think that is what was bothering me as I read about USB-C and what I wanted to do - unintended impact of plugging it into a USB-C Device. \$\endgroup\$
    – BlueSky
    Aug 8, 2020 at 1:04
In addition to the concerns above, just from a practical stand point, USBC has a lot of pins and therefore a very small pitch. Just assembling this connector on the board is going to be much harder than it needs to be.
