In the given solved example from a textbook on electronic devices, the author has use the voltage divider rule after assuming \$V_{s2}=0\$. Clearly for equation 1 to be true, the current in the non inverting terminal \$i\$ must be 0.
Why is this true? In few other examples current is taken as zero in the inverting input terminal. I wish to know the reason behind this assumption and how to know out of the two which input terminal has zero current? Can the current be ever taken zero in both of them?
instead of just$
to start and end inline math. \$\endgroup\$
