// Hardware sets a RIS interrupt status bit
if(GPIO_PORTE_RIS_R & 0x10)
   // Software acknowledges the flag and clears the read-only RIS bit by setting ICR
   GPIO_PORTE_ICR_R = 0x10;
   // something useful
The above code should be self explanatory - the hardware flags a register bit, the software clears it. What I don't understand is why the code uses GPIO_PORTE_RIS_R & 0x10 to compare register value instead of GPIO_PORTE_RIS_R == 0x10.
== operation would probably equivalent to a CMP followed by a BEQ or BNE in assembly, or it can be SUBS with a branch by flagging the Z (Zero) bit. Either way using == is straightforward and intuitive - I don't have to convert values into binaries to predict an outcome.
But with & and say if GPIO_PORTE_RIS_R = 0x20, the logical bitwise AND operation between 0x20 & 0x10 or 0010.0000 & 0001.0000 in binary will result in 0000.0000 or a false. And imagine if GPIO_PORTE_RIS_R = 0x30 or 0011.0000 in binary, the condition statement would return true even if the two operands (0x30 & 0x10) don't equate. It seems as if the & operator checks if a register contains a value (or vice versa, a register is subset of a value). It's just confusing to think or use.
In what situation should I use & instead of == and why? And is there a simpler way to think about it?
    \$\begingroup\$ One more thing: in C, logical AND is && and bitwise AND is &. \$\endgroup\$
    – The Photon
    Aug 12, 2020 at 5:45
When you write if REG & 0x10 you're checking whether bit 4 of the register REG is set.
If the value of REG is 0x30, then bit 4 is set, and you should do the thing you want to do when bit 4 is set.
If the value of the REG is 0x20 then bit 4 isn't set, so you shouldn't do the thing you want to do when bit 4 is set.
And that's exactly the behavior you get if you write if REG & 0x10 {...}.
If you used == then if bit 4 was set, but some other bit was also set, then you wouldn't do whatever it is you want to do when bit 4 is set.
But since you want to do that thing when bit 4 is set regardless of what other bits are set, then this is wrong.
Rule of thumb:
  • Use & when you care about individual bits and only those bits.
  • Use == when you care about the whole value of a variable.
You can of course also use & to check a whole variable against a mask, and in that case it is almost equivalent to ==. Except & returns either zero or a non-zero value, while == always returns either 0 or 1.
Advanced differences:
Both operators are equivalent when it comes to order of evaluation - it is unspecified. They are equivalent when it comes to implicit type promotions, except the result of & is always of the type of the (promoted) operands, while the result of == is always int.
Example (32 bit computer):
uint64_t a;
uint64_t b;
printf("%zu\n", sizeof (a & b));  // prints 8
printf("%zu\n", sizeof (a == b)); // prints 4
  • \$\begingroup\$ For C++ users: == returns a bool. \$\endgroup\$
    – Arsenal
    Aug 12, 2020 at 11:04
