The title for this question might not make a lot of sense, and for that I apologize.
I am currently working on setting up electronics inside a school bus to RV conversion I've been working on. For the head unit, I'll be using a Raspberry Pi, which will be the source of audio. I want to have two "groups" of speakers - one for sound inside the bus and another for outside. My end goal is to be able to a) use only the inside speaker group, b) use only the outside speaker group, or c) use both speaker groups at the same time.
What I am imagining is having some sort of buttons/switch setup between the amplifier and speaker groups that will allow me to specify what groups will be receiving the audio signal. Based on my searching, the first things that really sticks out to me a 1-2-both battery switch used to charge either one, another, or both batteries off of a single alternator. Obviously that's not correct for this application, but it's at least a start.
Very much looking forward to any and all suggestions, I'm pretty open to anything. Thank you!
  • \$\begingroup\$ Can you add more details about the amplifier you have chosen and the speakers ? Does the amplifier have multiple outputs which can be switched off independently ? If you are splitting the audio after power amplifier, you have to take impedance matching into consideration. It would be easier to split and switch the audio between the jack and the amplifier. Then you would need two amplifiers or amplifier with two outputs which can be switched independently. \$\endgroup\$ – AJN Aug 12 '20 at 7:24
  • \$\begingroup\$ The data required to work out a solution would be the output power and impedance of the amplifier and the power and impedance of the speakers. \$\endgroup\$ – vu2nan Aug 12 '20 at 17:01
Search "speaker switch box" on Ebay
That was not hard
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=speaker+switch+box&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=speaker+switch
