What is "Pointer" in DM14 at J1939 CAN-bus standard? Can it be the memory Address[DEC]?
That pointer contains a value which is the address of memory to be used for the read or write operation.
  • \$\begingroup\$ So if I got the address of EEPROM memory 200, then I should write 200 to the Pointer? And the length is the lenght of the EEPROM memory value e.g. 2 bytes? \$\endgroup\$
    – MrYui
    Aug 13 '20 at 23:28
  • \$\begingroup\$ That would be my guess, yes. \$\endgroup\$
    – Justme
    Aug 14 '20 at 8:46
  • \$\begingroup\$ Ok. I take that as an answer. J1939-21 is not an well explained protocol. \$\endgroup\$
    – MrYui
    Aug 14 '20 at 9:33
