I was wondering if there is anything I can do to make a visible laser pointer uv with (or without) messing with the laser. like if I simply shot the laser pointer through some device or screen that would shorten the wavelength? thanks for any help.
1 Answer
Lasers can be frequency doubled using nonlinear media. However, the process is not simple, and typically requires precise alignment and materials engineered for the specific wavelength or else extremely high power.
In spite of the cost, this method is used to double 532nm lasers to generate 266nm (or in reality to quadruple 1064nm lasers). For longer near-UV wavelengths, it's usually cheaper to buy a direct UV source. There are fairly cheap laser diodes above 350nm.
\$\begingroup\$ So I can buy a UV laser diode? I'm trying to find or make/modify some sort of laser like beam that is high enough to not be technically visible. Thanks \$\endgroup\$– Af91Commented Aug 18, 2020 at 5:08
\$\begingroup\$ @Af91 did you google it? \$\endgroup\$ Commented Aug 18, 2020 at 9:44
\$\begingroup\$ thorlabs.com/newgrouppage9.cfm?objectgroup_id=5400 \$\endgroup\$– Af91Commented Aug 19, 2020 at 17:34
c
