I am curious about how to wire DRAM to an SoC. What is required for optimal usage other than the net itself? I have seen conflicting information on if you should or should not use a termination resistor (here). There hasn't been much information I could find on connecting DRAM, which makes me think that a direct connection is what most board designers use, as otherwise there would be information on what would be needed to reduce EMI. I'm planning on using Micron MT40A1G8SA-062E for DDR4 RAM and a MIMX8MM6DVTLZAA SoC by NXP.
  • \$\begingroup\$ DRAM is a broad term, you need to provide which memory interface you wish to terminate. A datasheet or part number would be helpful. Not every SoC can interface to every DRAM (many drams use transceivers) \$\endgroup\$
    – Voltage Spike
    Aug 18, 2020 at 17:37
  • \$\begingroup\$ @VoltageSpike Hi, currently I'm looking at using MT40A1G8SA-062E by Micron for DDR4. \$\endgroup\$ Aug 18, 2020 at 17:42
  • \$\begingroup\$ And which SoC? Can you edit your question? \$\endgroup\$
    – Voltage Spike
    Aug 18, 2020 at 17:43
  • \$\begingroup\$ @VoltageSpike Just edited. I'm using a MIMX8MM6DVTLZAA SoC. \$\endgroup\$ Aug 18, 2020 at 17:46
