I would like to purchase a Power supply to test my unit in production environment. The power supply is expected to support a production yield of 1 Million units per year. As per one of the test requirements, I am required to supply/output 100 Amps of current for 5 seconds at 2Volts DC. One of the DC supply I am looking at could supply 110A at 10V. I want to know if it's a good idea to buy this power supply since it rated for only 10% above the maximum UUT required current.
Could someone name a Standard (any free resources if available on the internet) that would contain such guidelines? Thank you.
    \$\begingroup\$ This question will likely be closed as either needs focus (since you are asking multiple things) or off-topic (since one of the questions is a purchasing recommendation). You should narrow this down to a single question and make sure the title agrees with the body of the question. \$\endgroup\$ Aug 18, 2020 at 16:58
    \$\begingroup\$ You need to qualify the test as part of your overall production plan. Sometimes it is impossible on paper to understand if a particular device will meet your requirements - you may need to buy it or rent it to understand if it will work or not. A rule of thumb: the tester should test the product, the product should not test the tester. MTBF is a function of component stress (volts, amps, degrees) - the closer you run something to flat-out, the shorter it will last. I doubt there is a comprehensive standard for this. \$\endgroup\$ Aug 18, 2020 at 17:08
  • \$\begingroup\$ People make hi pot testers that do all the testing for you \$\endgroup\$
    – Voltage Spike
    Aug 21, 2020 at 6:07
  • \$\begingroup\$ Talk to a regulatory consultant, they'll be your best resource \$\endgroup\$
    – Voltage Spike
    Aug 21, 2020 at 6:08
You will be cycling this power supply at 5,000 events per day, for 200 days a year, to reach the 1,000,000 goal. This is every 18 seconds, at 3 shifts a day.
Chances are the thermal cycling will cause quick failure.
So chat with the manufacturer, especially the Reliability or Quality people.
