I want to use this Single Cell Li-Ion Battery Charger (MCP73833). The pins STAT1 STAT2 and /PG are an open collector outputs and it will be connected to low power LEDs as shown in the schematic. If I would also like to connect these pins to 5V tolerant open drain GPIO pins of the PIC32MZ microcontroller to also be able to control the LEDs by the microcontroller. Will this direct connection work?enter image description here
  • \$\begingroup\$ Is your micro running of the same 5V supply or is it, e.g. 3.3V? \$\endgroup\$
    – Jay M
    Aug 26, 2020 at 11:37
  • \$\begingroup\$ MCU is running 3.3V \$\endgroup\$ Aug 26, 2020 at 20:49
No it will not work because the LEDs will hold the input voltage above 2V. Also note that you've chosen to run the LEDs at a higher current than the battery charger chip guarantees the output voltage at. Even at 4mA only 1V 'low' is guaranteed.
The PIC32MZ requires input voltage for a '0' of less than 0.2Vdd and for a '1' more than 0.8Vdd. You also should provide a bit of margin.
Easiest thing would be to pull the pins up to Vdd with something like 10K, and drive the LEDs with a few MOSFETs or a CMOS inverter or gate package.
The open-drain outputs on the PIC will be High-Impedance when not switched on, so there will be no contention with the asynchronous open-collector outputs on the battery charger. It will cause an issue only when one output has activated a LED, the other output will not be able to disactivate it if you wish to do that, say from software (and vice-versa from battery charger). Depends if this is an issue for you … Presumably the STAT1 and STAT2 are also open-drain outputs that are there to indicate various states of the battery charger, like charge ON, OFF or charger FAULT condition. You will need however to ensure the PiC is also running of 5V, otherwise, use external MOSFETS.
Is there some reason you can't do it the normal way, as shown below? Schematic for open drain connections
OK Perhaps your Pic is running on a lower voltage , and doesn't have "proper" open collector outputs, the solution is to use cascode type level shifters, these are just another mosfet "in series" with the internal one, with the gate tied to 3v. You need a MOSFET like the 2n7002 with a typical 1v threshold. The circuit will allow level translation to much higher voltages , e.g. 24v is quite common , and is bi-directional, so you could put a push button to ground on any or all of the signal lines. (The schematic is missing Q2, it is wired the same as the other two, wasn't enough space to squeeze it in).
cascode
I've redrawn using a different MOSFET symbol, this shows the internal diode, and I've fitted Q2 in as well. The internal diode is what makes it bi-directional, once the drain drops below 3v, it drags the source down with it, eventually causing the MOSFET to conduct below about 1.5v, and Source and drain are then at the same voltage. I've also shown a pushbutton. Cascode with PB
