I would like to use the NXP TJA1046/TJA1048 dual CAN transceiver to connect to two CAN BUS. I would like to mux the TX1/TX2 and RX1/RX2 and connect them to single TX/RX interface on the MCU. In order to avoid conflict, I can put one of the block into standby mode and vice versa. Please check the attached picture and see if my implementation makes any sense.
Thank you
