I was hoping that some of you experts could help me identify a SMD on the back of a 1080 ti FE. This item was dropped and it appears has some damage done to it. I would like to replace the missing SMD if possible but having problems identifying what they are.
I know the part is still in production because I have identified it on the newer 2080 ti but still unable to find it.
I have attached the image of the back of the 1080ti. I have specified different sections. I am only Concerned about section A and B.
Section A: This is were I believe two SOT-353 SMD's have been knocked off. I think I located a similar circuit on the board that identifies the missing SMD. (Section B)
I couldn't find anything on mouser or digikey that match the code.
Parts Symbol "VT" there are two ".." under the "V" with a sideways "5" I have found possibilities on the internet but not sure if they are correct?
R1122N171B -- Linear voltage regulator IC
RT9198-20PBR -- LinearRegulatorIC
Any help would be appreciated.
Its not as detailed as my own but here is a reference pic of the back of the pcb.
Thxs
