I'm seeing unexpected data on the A & B outputs of my ALPS incremental rotary encoder. The A & B pins are are attached to a microcontroller with pull-ups enabled and the centre pin is ground The pulses are aligned on their rising or falling edges rather than being 90 deg out of phase as I expected (and documented everywhere). Attached are two capture screenshots, one for clockwise the other anticlockwise rotation. Am I missing something?
\$\begingroup\$ You are missing the all-important link to the data sheet. \$\endgroup\$– Andy akaAug 24, 2020 at 15:43
1\$\begingroup\$ Looks like channel 1 is getting ANDed with channel 2. If it were a simple short, I’d expect both would rise or fall together, so I think the fault is more complex. If you have other pins available on the MCU, try the same setup on different pins; if it’s the same, try another encoder. \$\endgroup\$– Russell BorogoveAug 24, 2020 at 15:48
\$\begingroup\$ Link to [datasheet] (docs.rs-online.com/8546/0900766b810a5d53.pdf) \$\endgroup\$– Bruce AlportAug 24, 2020 at 16:00
\$\begingroup\$ I've tried connecting to other pins on the microcontroller, same output. Only have the one encoder to hand. \$\endgroup\$– Bruce AlportAug 24, 2020 at 16:02
\$\begingroup\$ Which specfic part number you have, and does it match to what you ordered? Are you sure it is not a wrong part with absolute output? \$\endgroup\$– JustmeAug 24, 2020 at 16:38
1 Answer
You have, most likely, connected pin A or B to ground instead of C.
Figure 1. Encoder pinout. (Click to enlarge.)
Figure 2. (1) Encoder ABC. (2) Push-button pins.
Now that C is the centre pin.
Figure 3. In (a) 'A' requires both switches to close before it will pull low. This will occur 25% of the time. 'B' just requires SW2 to be closed to pull low. This will occur 50% of the time.
\$\begingroup\$ Genius! - That's exactly what it was \$\endgroup\$ Aug 24, 2020 at 21:06
