If you use PCIe on an x86 system, you will need DMA in the endpoint. Otherwise your transfers will be quite slow, as x86 platforms don't tend to have host-side DMA resources. Reads, especially will be painful as they're non-posted and take a long overhead for each transfer.
In Xilinx-land, the most popular PCIe bridge block is called 'xdma', which is documented in PG195. This block supports memory-mapped or streaming DMA, and has drivers available for Linux and Windows. While it's not terribly complicated, you do need some kernel expertise to integrate it with your application. It's a well-known block, and there's lots of chatter on the Xilinx forums about it.
There's a couple of other IP blocks in Xilinx (like cdma and vdma), or you can purchase a block as IP from companies like Northwest Logic.
As far as how PCIe devices 'work', they are enumerated at boot time using I/O, and configured by the driver to live in a specific set of memory address spaces, called 'resources' in Linux and BARs in PCIe. The way you communicate with a device is you ask for its virtual address when you 'open' it, then you can read/write to that address. That address isn't fixed: it changes as it's assigned by the MMU each time you open the device.
If you want to see how that works, the utility 'pcimem' (Linux) shows a very basic way to do that. It's a simple program that does peek/poke to any PCIe device.
