I have a PSU that had a D667A NPN transistor that took some damage. I am not 100% sure what its goal is in the circuit, but I have the impression it is used to drive the power transistor mounted on the heatsink you see in the picture.
The psu had a fuse that got blown violently, and there were some shorted components in the PSU (shorted power transistor, shorted electrolytic cap, shorted schottky diode)
I replaced the shorted components, and replaced the D667A NPN transistor this particular transistor with a BD139 NPN transistor I had lying around.
The original D667A NPN transistor datasheet mentions a transition frequency of 140Mhz.
In the BD139 NPN transistor datasheet I could not find this frequency, although other sites mention it as being 190Mhz. The other parameters were the closest I had compared to the original one, making me think (perhaps wrongly) that this is a suitable replacement.
Is my thinking correct, or should I replace it with a more suitable transistor. And if so, what would that replacement be ?
Although the fuse is kept intact now, I am not seeing any DC output voltage, so I am wondering if this BD139 might be the cause of that. (it not being able to turn on the power transition properly).
  • \$\begingroup\$ Ah, I know a switching mode power supply unit frequency is usually only a couple of kHz. So your new BD139 should have no problem handling it. WARNING: I am only a friendly hobbyist. No guarantee no nothing won't melt down or blow up. Good luck and cheers. PS - Your photo looks impressively very high standard, compared with your electronics. \$\endgroup\$
    – tlfong01
    Aug 25 '20 at 8:43
    \$\begingroup\$ @tlfong01 it's highly likely that the switching frequency is many tens of kHz and can be hundreds of kHz so your message is not really useful. Additionally, without some idea what voltages are involved, you should not state that the BD139 should have no problems given that the original transistor is rated for 100 volts operation whilst the BD139 is only 80 volt rating. There may be other things also that make it unsuitable. I don't think your comment brings anything useful to the party. \$\endgroup\$
    Aug 25 '20 at 9:42
    \$\begingroup\$ Even if you do find the right replacement, how do you know anything else did not take any damage ? Otherwise why not replace it with the original such as advertised here : bdent.com/nsearch.html?query=2SD667A ? \$\endgroup\$
    – citizen
    Aug 25 '20 at 9:51
  • \$\begingroup\$ @Andy aka, my apologies for my casual misleading comment that SMPS freq is a couple of kHz. I confess that my SMPS knowledge is out of date. I do remember some 20 years ago when I repaired ATX12 or earlier PSU, I did hear the buzzing nose, which means the frequency should be less than 20kHz. Some 10 years ago, I actually bought inductor coils and designed an LM2596 switching power supply. But the inductor values are discrete, in big steps, so I actually spent some 50 hours studying the theory and another 50 hours using a scope to measure the inductances./ to continue, ... \$\endgroup\$
    – tlfong01
    Aug 25 '20 at 12:38
  • \$\begingroup\$ If you search the word inductance, in rpi.org.forum, you should find 20+ lont posts sharing my experiments in inductance. I forgot the frequency of my final version of DIY SMPS, but for sure less then 500kHz. So I am pretty sure that the OP's a bit old UPS's frequency should be less than 500kHz. So when I read the OP worrying 100MHz or 200Mhz, I did LOL. In short, I think my quick and dirty reply is very appropriate to the OP, considering my time constrain. In weekends, I often comment/chat with the OPs, sometimes 20 pages, lasting 2 weeks, before I propose my suggestions. / to continue, ... \$\endgroup\$
    – tlfong01
    Aug 25 '20 at 12:48
