My Deta 1121 carbon monoxide detector is showing no lights. I'd like to test the ceiling socket to determine if the fault is with the wiring or with the detector.
A separate heat detector is on the same RCB circuit and powered on, so I'm hopeful it's just the CO detector that needs replacing.
I have an earlier version of the Silverline 513121 multimeter and believe these are the correct settings to use when testing UK mains electricity: multi meter settings for mains checks
My plan to test if the circuit is live is to:
  1. Set the Multimeter to 600V AC ~
  2. Place the black probe on the Neutral (grey wire) screw
  3. Place the red probe on the Live (brown wire) screw
Could anyone please confirm that sounds sensible?
    \$\begingroup\$ This isn't an electronics design question. I'll request migration to DIY. \$\endgroup\$
    – Transistor
    Commented Aug 25, 2020 at 10:09
    \$\begingroup\$ @Whiskeyjack OP mentioned that they are in the UK, so around 240 V would be the correct voltage. \$\endgroup\$ Commented Aug 25, 2020 at 10:57
    \$\begingroup\$ Sorry guys, I mixed up US and UK. For UK you should expect 220-240 VAC. \$\endgroup\$ Commented Aug 25, 2020 at 11:19
  • 5
    \$\begingroup\$ Nicely presented question! Yes, suggested method is good. \$\endgroup\$
    – Russell McMahon
    Commented Aug 25, 2020 at 11:37
    \$\begingroup\$ I agree, this is a very nicely written question. \$\endgroup\$ Commented Aug 25, 2020 at 11:39
I've just done the test as outlined:
  3. Place the rede probe on the Live (brown wire) screw
And got a reading of 243V on the multi-meter. Thanks for the feedback in the comments.
  • \$\begingroup\$ The irony is after all that the Deta 1121 is now no longer available to buy so I can't just swap in a new one. :) \$\endgroup\$
    – James T
    Commented Aug 25, 2020 at 12:40
  • \$\begingroup\$ Ah! It looks like the BRK CO850MBXi has a compatible base. \$\endgroup\$
    – James T
    Commented Aug 25, 2020 at 15:14
