I have to repair a led tv with a blown fuse. On the power board the fuse required is a T4.0AH/250V fuse, but I couldn't find it at the shop. They gave me instead a radial fuse, claiming that it's the same. Is it possible to replace a ceramic fuse with a radial one or could blown other parts of the board?
  • \$\begingroup\$ When you say a ceramic fuse, do you mean a HRC fuse? \$\endgroup\$ – Hearth Aug 25 at 13:17
  • \$\begingroup\$ If rated for 250Vac and has line filter OK to suppress 4kV transients \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Aug 25 at 13:19
  • \$\begingroup\$ Data sheets required for both parts. \$\endgroup\$ – Andy aka Aug 25 at 14:16
  • \$\begingroup\$ The term "ceramic fuse" is nearly meaningless, except perhaps within the narrow context of the type of consumer electronics you're working on. If you don't have a datasheet, post a picture. \$\endgroup\$ – TimWescott Aug 25 at 15:19
  • \$\begingroup\$ No, fuses have specs that need to be matched, without seeing the application or info on the fuses this question cannot be answered. \$\endgroup\$ – Voltage Spike Aug 25 at 21:23
T4.0AH/250V stands for "slow acting, 4A, high breaking capacity, 250V voltage rating". The one you got just says "4A" and unless there are other markings on it not in the photo, there is no way to tell if it is an acceptable replacement (so it isn't 8-).
| improve this answer | |
  • \$\begingroup\$ Ok but is it possible to use a radial fuse as replacement for a ceramic one? I mean what's the practical difference between them? \$\endgroup\$ – anemiCCinema Aug 25 at 14:51
    \$\begingroup\$ If all the specs are the same, then yes, it is possible. Ceramic fuses tend to have a much higher breaking capacity, though, see en.wikipedia.org/wiki/Fuse_%28electrical%29#Breaking_capacity . \$\endgroup\$ – ocrdu Aug 25 at 15:21
    \$\begingroup\$ One is ceramic, the other is round -- and then there's all the possible things that could be different inside, that you can -- practically -- only tell with detailed specifications. So yes, you can replace "a ceramic fuse" with exactly the right radial fuse -- or you can replace "a ceramic fuse" with another ceramic fuse that's totally wrong, and it'll utterly fail at its job. \$\endgroup\$ – TimWescott Aug 25 at 15:21
It is unlikely that some random 4A fuse the shopkeeper has on hand (lacking any safety approval markings, at that) will match the characteristics of the ceramic fuse in terms of breaking capacity (perhaps 400A rating) and time delay characteristics.
So there is some risk of it nuisance blowing or not providing proper protection.
