I know that the code I am going a publush is terrible and pointless, just I am playing trying to go deep in verilog, deep to gate behaviour... Well, this is the pain code:
module syncRX(clk, signal, detect);
    input clk, signal;
    output wire [7:0] detect;
    reg rst = 0;
    reg [7:0] counter = 0;
    wire [7:0] aux;
    freq_div div(.clk(clk), .clk_1khz(clk_1khz));
    rsff rs0(.r(rst), .s(aux[0]), .q(detect[0]));
    rsff rs1(.r(rst), .s(aux[1]), .q(detect[1]));
    rsff rs2(.r(rst), .s(aux[2]), .q(detect[2]));
    rsff rs3(.r(rst), .s(aux[3]), .q(detect[3]));
    rsff rs4(.r(rst), .s(aux[4]), .q(detect[4]));
    rsff rs5(.r(rst), .s(aux[5]), .q(detect[5]));
    rsff rs6(.r(rst), .s(aux[6]), .q(detect[6]));
    rsff rs7(.r(rst), .s(aux[7]), .q(detect[7]));
    always @(posedge signal or posedge clk_1khz)
        if(signal == 1'b1)
            begin
                rst = 1;
                rst = 0;
                aux <= counter;
                counter <= 0;
            end
        else
            counter <= counter + 1;
endmodule // top
module freq_div(input clk, output reg clk_1khz);
    reg [18:0] count = 0;
    always @(posedge clk)
     begin
        if(count == 60000)
            begin
                clk_1khz <= ~clk_1khz;
                count <= 0;
            end
        else
            count <= count + 1;
     end
endmodule
module rsff(r, s, q);
    input r,s;
    output q;
    nand(~s,qbar,q);
    nand(~r,q,qbar);
endmodule
The idea is to take a "snapshot" of the counter before reset it, being this "snapshot" the output of the module (I know there is an other way to do, but I want to solve in gate level). I am using an ICE40 FPGA and it should show a 8 bit binary number in the leds representing the cycle of "signal" counted by "clk_1khz". I got an timming error. But can not find out why... Thanks.
Append: The error:
nextpnr-ice40 --hx8k --package tq144:4k --json syncRX.json --pcf syncRX.pcf --asc syncRX.asc
Info: constrained 'signal' to bel 'X0/Y25/io1'
Info: constrained 'detect[0]' to bel 'X12/Y0/io1'
Info: constrained 'detect[1]' to bel 'X12/Y0/io0'
Info: constrained 'detect[2]' to bel 'X11/Y0/io1'
Info: constrained 'detect[3]' to bel 'X8/Y0/io0'
Info: constrained 'detect[4]' to bel 'X7/Y0/io1'
Info: constrained 'detect[5]' to bel 'X6/Y0/io1'
Info: constrained 'detect[6]' to bel 'X4/Y0/io1'
Info: constrained 'detect[7]' to bel 'X4/Y0/io0'
Info: constrained 'clk' to bel 'X16/Y0/io1'
Info: Packing constants..
Info: Packing IOs..
Info: Packing LUT-FFs..
Info:        0 LCs used as LUT4 only
Info:        0 LCs used as LUT4 and DFF
Info: Packing non-LUT FFs..
Info:        0 LCs used as DFF only
Info: Packing carries..
Info:        0 LCs used as CARRY only
Info: Packing RAMs..
Info: Placing PLLs..
Info: Packing special functions..
Info: Promoting globals..
Info: Constraining chains...
Info:        0 LCs used to legalise carry chains.
Info: Checksum: 0xd7159a06
Info: Annotating ports with timing budgets for target frequency 12.00 MHz
Info: Checksum: 0x8078c586
Info: Device utilisation:
Info:            ICESTORM_LC:     1/ 7680     0%
Info:           ICESTORM_RAM:     0/   32     0%
Info:                  SB_IO:    10/  256     3%
Info:                  SB_GB:     0/    8     0%
Info:           ICESTORM_PLL:     0/    2     0%
Info:            SB_WARMBOOT:     0/    1     0%
Info: Placed 10 cells based on constraints.
Info: Creating initial analytic placement for 0 cells, random placement wirelen = 0.
Info:     at initial placer iter 0, wirelen = 0
Info:     at initial placer iter 1, wirelen = 0
Info:     at initial placer iter 2, wirelen = 0
Info:     at initial placer iter 3, wirelen = 0
Info: Running main analytical placer.
Info: HeAP Placer Time: 0.00s
Info:   of which solving equations: 0.00s
Info:   of which spreading cells: 0.00s
Info:   of which strict legalisation: 0.00s
Info: Running simulated annealing placer for refinement.
Info:   at iteration #1: temp = 0.000000, timing cost = 0, wirelen = 0
Info:   at iteration #2: temp = 0.000000, timing cost = 0, wirelen = 0
Info: SA placement time 0.00s
Warning: No clocks found in design
Info: Checksum: 0xe3e91e09
Info: Routing..
Info: Setting up routing queue.
Info: Routing 0 arcs.
Info:            |   (re-)routed arcs  |   delta    | remaining
Info:    IterCnt |  w/ripup   wo/ripup |  w/r  wo/r |      arcs
Info:          0 |        0          0 |    0     0 |         0
Info: Routing complete.
Info: Route time 0.00s
Info: Checksum: 0x0a0c3218
Expected waveform
Pretended schematic
I can not underestand why the code with this modification works...
    input clk, signal;
    reg rst = 0;
    wire [7:0] aux;
    assign detect = counter;
        if(signal == 1'b1)
            begin
                rst = 1;
                rst = 0;
                aux <= counter;
                counter <= 0;
            end
        else
endmodule // top
Thanks
    \$\begingroup\$ Please include the exact text of the error message you got. \$\endgroup\$
    – The Photon
    Aug 25, 2020 at 17:48
  • \$\begingroup\$ @ThePhoton sure! I add the full log in the question (is too big for a comment). Thanks! \$\endgroup\$
    – Carlos J.
    Aug 25, 2020 at 19:32
  • \$\begingroup\$ Where is the timing error? \$\endgroup\$
    – The Photon
    Aug 25, 2020 at 21:26
  • \$\begingroup\$ One thing I'll point out is that where you have rst = 1; rst = 0; That will probably just synthesize to rst being set to zero. It won't generate a pulse on rst to trigger the RS flops. You probably want to set rst to 1 when the signal goes high, and then find a way to return it to zero after some controlled delay. Exactly how to do that depends on what you're trying to achieve. \$\endgroup\$
    – The Photon
    Aug 25, 2020 at 21:30
  • \$\begingroup\$ @ThePhoton I am using Icestorm tools and it seams too gentle with errors, it compile but FPGA is doing nothing, but if comment the line 25 "//aux <= counter;" and add bellow line 7 "assign detect = counter;" not only compile, the FPGA works as a counter. Then I take the "Warning: No clocks found in design" as an error (always when I get this warning everything stop working) \$\endgroup\$
    – Carlos J.
    Aug 26, 2020 at 11:38
The problem is here:
    if(signal == 1'b1)
        begin
            rst = 1;
            rst = 0;
            aux <= counter; // Here
            counter <= 0;
        end
    else
You are using signal as a reset for the flip-flops that produce counter, which is perfectly all right.
But for aux you are trying to have two different clock inputs (signal and clk_1khz) trigger it capture the value from counter. As we discussed in your previous question, that isn't synthesizable.
You also have a problem with rst: You can't synthesize two different transitions of the signal on the same clock edge. In synthesis, the net result of rst = 1; rst = 0; will just be to set rst low. Meaning that rst will simply never go high. You should find a way to set it high when the reset (signal) occurs, and then set it low after signal goes low again.
  • \$\begingroup\$ Thanks a lot. Just a question "rst = 0;" is blocking. This dont mean that have to commit the action before happends the next line? because in that case should give a signal. \$\endgroup\$
    – Carlos J.
    Aug 26, 2020 at 15:09
  • \$\begingroup\$ about aux is in two different clock, I see counter in two different clock but not aux (is not a critic, just ask because maybe you saw something I didnt), anyway they are handled inside a "IF" stament, then should be synthetizable... I guess. Thanks a lot for your hel, and for be patient with my, I still have to learn a lot about this technology \$\endgroup\$
    – Carlos J.
    Aug 26, 2020 at 15:16
  • \$\begingroup\$ @CarlosJ., when either signal or clk_1khz has a rising edge, aux gets the value from counter. That's two different clocks controlling aux and it isn't synthesizable. You can use an if-statement to generate reset logic, but only if you assign the value from a constant (not another signal) inside the if-statement. \$\endgroup\$
    – The Photon
    Aug 26, 2020 at 15:19
  • \$\begingroup\$ your answer make sense... Do you think that change the "else" to "else if(clk_1khz == 1'b1)" could solve the situation? (with this modification would never "aux" be controlled in the same time). Thanks! \$\endgroup\$
    – Carlos J.
    Aug 27, 2020 at 12:31
  • \$\begingroup\$ No, was not good idea, is not even compiling... and also, is not making even logical diference... Anyway, I think I didnt get your point, there is two edges, but also there is an "if - else" structure, is going never a be modificate "aux" in the same time bought edges... Maybe I am missing something... \$\endgroup\$
    – Carlos J.
    Aug 27, 2020 at 12:56
