I'm using CH9329, a uart to USB keyboard/mouse simulator chip, to simulate mouse movement, with a moveable signal sender and an esp32-based signal receiver connected to it.
[sender] -> signal
signal -> [receiver->ch9329(simulate mouse)->computer]
Now I can see while I am moving my sender, the simulated cursor correctly moves and it also responses to mouse click (by clicking some desktop buttons). But, the weird thing is, if I open a whiteboard program, and want to draw a line, the cursor clicks at the first point, showing a visiable dot, but then failed to draw other points (moved correctly). However, I'm sure I am sending the right packet to indicate the mouse button is down (through uart tools).
In one sentence, it seems in all my "left-button-down" data packets, only the first packet really clicked, while other packets just let the mouse move.
How can this be possible? Any ideas? I think real mouses also report positions in the form of discrete points to the host, and the host knows how to draw a line. But my case failed.
--Edit--
I assume when using a real mouse to draw a line in a general painting program, you press the left button and then holding the button to keep it down, when you finish drawing you let the button up, right? That's what I did.
The chip protocol uses a byte to indicate the mouse state in every mouse-host communication packet. A 0x01 means the left button is down and a 0x00 means the left button is up. And when I detected a esp32 button is pressed, I begin sending 0x01 down packet, when I detected that esp32 button is up, I then changed to send 0x00 up packet.
My logs showing the button and packets I send:
.[0;32mI (95069) uart-mouse: sending to host : mouse state: 0
.[0m
.[0;32mI (95089) uart-mouse: sending to host : mouse state: 0
.[0m
.[0;32mI (95089) server-main: btn clicked
.[0m
.[0;32mI (95089) uart-mouse: sending to host : mouse state: 1
.[0m
.[0;32mI (95109) uart-mouse: sending to host : mouse state: 1
.[0m
.[0;32mI (95129) uart-mouse: sending to host : mouse state: 1
.[0m
.[0;32mI (95149) uart-mouse: sending to host : mouse state: 1
.[0m
.[0;32mI (95169) uart-mouse: sending to host : mouse state: 1
.[0m
.[0;32mI (95189) uart-mouse: sending to host : mouse state: 1
.[0m
.[0;32mI (95209) uart-mouse: sending to host : mouse state: 1
.[0m
.[0;32mI (95229) uart-mouse: sending to host : mouse state: 1
.[0m
.[0;32mI (95249) uart-mouse: sending to host : mouse state: 1
.[0m
.[0;32mI (95269) uart-mouse: sending to host : mouse state: 1
.[0m
.[0;32mI (95289) uart-mouse: sending to host : mouse state: 1
.[0m
.[0;32mI (95299) server-main: btn released
.[0m
.[0;32mI (95299) uart-mouse: sending to host : mouse state: 0
.[0m
.[0;32mI (95309) uart-mouse: sending to host : mouse state: 0
.[0m
.[0;32mI (95329) uart-mouse: sending to host : mouse state: 0
.[0m
    \$\begingroup\$ To draw a line on most OSs and programs, the mouse must first give left button DOWN signal, not left button CLICKED signal. a click is a button DOWN immediately followed by button UP. Are you sending button down followed by multiple mouse moved followed by a button UP packets ? \$\endgroup\$ – AJN Aug 27 '20 at 15:15
  • \$\begingroup\$ Link 1 Linux link 2 Windows Link 3 Windows read last sentence "*I'm sure I am sending the right packet to indicate the mouse button is clicked *" Can you show a sample output set ? \$\endgroup\$ – AJN Aug 27 '20 at 15:21
  • \$\begingroup\$ @AJN I misused the world 'click' someway and I actually let the mouse button down by pressing a button on esp32 when begin drawing, keep the buttons down then, and finally let the mouse up by releasing the esp32 button. So it's a 'down - holding down - up' process. \$\endgroup\$ – lincr Aug 28 '20 at 1:47
  • \$\begingroup\$ Besides I'm using macOS and drawing using an online whiteboard: https//w-xuefeng.github.io/drawing/ \$\endgroup\$ – lincr Aug 28 '20 at 1:49
Finally I found the reason, I made a phone call to the chip FAE, and found that I should send packets of relative mouse location if I want to draw a line. And I previously used absolute mouse location all the time. Though absolute location method works in general scenarios, drawing may be a case that it cannot work.
