I am not a full fledged electrical engineer, and I couldn't find it on google, may be because I couldn't think of better combination of keywords. My question is, if we have a simple transformer with a primary coil of 500 turns and on the secondary side of transformer, we have 10 different independent coils of 500 turns each of exactly same thickness of wire to that of primary coil; and if we input 100 volts, 20 ampere AC into primary coil, will it produce 100 volts, 20 ampere AC into each secondary coil individually, or the voltage among each individual secondary coil will be (100 x 10)/10 and will the current be (20/10)/10 = 0.2 amps?
Another quick question is, will the length of transformer core affect the total magnetic flux, if the transformer core is very long and there's huge distance between single primary and single secondary coil of same turns and thickness, will the induced voltage in secondary be lesser because less flux will reach secondary coil and some flux will be absorbed in the core during travel of long distance?
