Recently I was thinking about a generator project and realized that is beyond my current understanding of AC power. I have been doing some research since but I am really having a hard time understanding the frequency part of AC power sources. From what I understand the frequency of an AC signal is the number of full +/- voltage cycles in a signal.
To make discussion simpler lets consider an A/C generator that is driven by a constant 1500 RPM. If that generator has has 4 poles this would result in 50 Hz, since there are 6000 magnet switches every minute, which is 3000 full voltage changes a minute which is 50 changes a second.
Now lets assume I have the same sort of generator (size, etc) but it has 12 poles like an usual car alternator, it will produce 150Hz AC power. At this point I am really wondering why any appliance would care. If you consider it within a full second nothing really changes, there is the same amount of time in positive voltage and negative voltage as if it would be running with 50Hz. It just switches three times more often.
Why exactly do A/C appliances care how often the voltage inverts with A/C power sources?
