Hi I want to make a buzzer for my PC motherboard. Similar things like this:
My plan is to use a normal speaker with a amplifier like LM386. Is it possible to connect LM386 inputs to PC motherboard buzzer output pin ?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityHi I want to make a buzzer for my PC motherboard. Similar things like this:
Motherboard speaker connections allow directly use of 8 ohm speaker. That's how they were originally designed in the 80's and they still are compatible.
There is no need for an amplifier, and in fact the motherboard speaker output pin is usually open-collector output so direct connection to amplifier input would most likely not work, it requires at least some biasing network to convert the open-collector output to voltage output.
