This IC is from a power supply for an LED domestic light
LED supply
PCB
This appears to be a 7 legged IC, at least it doesn’t seem to have had the 7th leg snipped.
9609 IC
The markings seem to be
9609SB
G8EMOS
I have had a google and I don’t think that it is an AD9609 ADC nor a 9609 MOSFET.
    \$\begingroup\$ Perhaps some sort of LED driver. Just a wild guess: datasheetspdf.com/pdf-file/1112315/SISemiconductors/SIC9753/1. Warning: me friendly hobbyist. No guarantee no nothing won't melt down or blow up. Good luck and cheers. \$\endgroup\$
    – tlfong01
    Commented Aug 31, 2020 at 6:31
  • \$\begingroup\$ Would you care to post your comment as an answer? \$\endgroup\$ Commented Dec 31, 2022 at 15:16
Here is a link to the datasheet, JD9609.
I was looking for the same IC and found the WS9002. I've checked the pin out and it is correct.
WS9002 application circuit
Please, reply if you find any replacement or a easy way of dimming it.
Check this out pin out. Looks similar to the part reference in the question.
MBI6655 Pinout
This application circuit has similar components per the question. Example Pin 4 SW is connected to diode.
MBI6655 application circuit
Here is link to the datasheet.
Additionally MB10 looks like a bridge rectifier. These should help identify the components.
  • \$\begingroup\$ Similar, but not quite, as pin 8 of the IC in my PCB is used (it's connected to two resistors). I will add a schematic of the PCB, it will probably help. \$\endgroup\$ Commented Aug 31, 2020 at 15:08
