I want to connect some SK9822 LEDs to an SPI bus that is already in use. As these LEDs do not have a chip select, I need to make one.
Is it just as simple as an npn transistor (BC547 perhaps)? Feed the chip select signal from microcontroller to the base, the collector to the microcontroller clock and the emitter to the first LED clock input?
Does this work this way and, if not, what is the correct way?
